Author Topic: 1956 negative battery strap  (Read 141 times)
Offline lexi
      CLC Member #28634
  • Name: C.R. Foley
« on: October 02, 2017, 12:19:59 PM »
Anybody know what the length is of the 1956 Cadillac negative braided metal battery strap? Much thanks. Clay/Lexi
« Last Edit: October 02, 2017, 12:23:34 PM by lexi »
Online J. Gomez
      CLC Member #23082
  • Name: J. Gomez
Re: 1956 negative battery strap
« Reply #1 on: October 02, 2017, 02:11:24 PM »
Clay,
According to the MPL is list them as 27" or 26 1/2" if you use the standard 3EE battery if you go with the higher CCA 3EH you need about 2" - 3" more to reach the terminal.
Good luck..!
J. Gomez
CLC #23082
Time is irrelevant when you work on your classic car, eventually you will enjoy it..!
Offline lexi
      CLC Member #28634
  • Name: C.R. Foley
« Reply #2 on: October 02, 2017, 03:23:53 PM »
Jose I thought it was 27 for 3EE but was not sure. Got an opportunity to purchase an NOS one. As usual, you are a life saver! Thanks! Clay/Lexi
Offline John Washburn CLC 1067
  • Call me on my shoe phone 303+885-3545
      CLC Member #1067
« Reply #3 on: October 09, 2017, 08:27:53 PM »
I bought an original negative braded battery cable for my 56. This is correct one with the hole to go in frame before connecting to the engine.
Problem was the new EE batteries moved the post so it does not work.
I have a nice original one if someone needs it. Perhaps the folks who make the original batteries can verify this.
The Johnny
John Washburn
CLC #1067
1937 LaSalle Coupe
1949 62 Series 4 Door
1953 Coupe DeVille
1956 Coupe DeVille
Online Jeff Rose CLC #28373
  • Name: Jeff Rose
« Reply #4 on: October 09, 2017, 08:44:13 PM »
Will it fit a 55?  I will have to measure mine.
CLC #28373
1970 Coupe DeVille
1955 Series 62
