'59 Cadillac - Brake lights coming on one side only.
Started by Eric DeVirgilis CLC# 8621, October 03, 2017, 08:47:24 AM
Park lamps, turn signals operating properly on both sides - no problem. Only when applying brakes - left pair of brake lights do not come on.
Any suggestions?
e.kempton
Bob Schuman
It's a distant memory, but a similar problem I had on a 59 Pontiac many years ago was a maladjusted turn signal switch near the bottom of the steering column inside the car. Could be the same on a 59 Cadillac.
Bob Schuman
Bob Schuman, CLC#254
2023 XT5
Well the left brake lights started working on their own. Thank you gentlemen for your input. I believe you are both correct on the turn signal switch contacts being the culprit.
