Please note that the Forums will be in Maintenance Mode, i.e. not accessible, this coming Wednesday, May 15th, This is to make backups and carry out the changes to make the forums only allow posting by CLC members. The start of the transition is planned for around 9 a.m. EDT, and is expected to last between four and eight hours.
6V to 12V Conversion; Radio ?
Started by jackworstell, October 03, 2017, 08:24:45 PM
jackworstell
We are thinking about converting our 1937 Cadillac series 60  from 6V to 12V.   The car still has the original 5X Wells Gardner radio and it works.
If we convert the car to 12V.......would inserting a resistor ( of appropriate ohms and wattage )   in series in the power wire to the radio take care of this aspect of the conversion ?    Or is it more complicated than this ?
Jack Worstell    #7558     jlwmaster@aol.com
1937 LaSalle coupe
Hello Jack. You are going from 6 volts positive ground to 12 volts negative ground. I would contact a professional radio rebuilder. Good luck... John C. Lehman ...
jackworstell
John...we would use a 12V positive ground alternator.....they are available.
Jack
klinebau
1970 Cadillac Deville Convertible
Detroit, MI
A resistor only sort of works for something that has a consistent load/draw.   Something like a radio likely varies somewhat depending on what is playing and how loud.   Other downside to a resistor is you are turning half the power into heat so its a waste especially for larger loads.
jackworstell
Don't even think about trying to use a resistor.  Generally tube radios
don't care about polarity, unless it uses a 6 pin vibrator or a dynamotor.
The simplest method could be a 12V to 6V switching (cool, efficient
operation) supply, needs to be filtered against radio interference.
I would NOT recommend a positive ground alternator.  Your radio
likely doesn't need it, hardly anything else cares, but any modern solid
state stuff you might want to use will want negative ground.  Bruce Roe
jackworstell
klinebau...thanks for the link....very interesting.   I found the explanation of how to make a 12V to 6V regulator complete and easy to understand
bcroe....would you happen to have a link describing a switching supply ?     No need to go into a detailed explanation here on the forum...just looking for a hint on where to go to so as to get a better understanding.
Jack
Best to buy a switcher of the needed capacity; they are somewhat complex
but cheap on Evil Bay and other places.  Some input and output filtering
will probably be needed if it isn't designed for the specific app.
The 7805 class reg is a LINEAR reg that will burn up the extra voltage,
dissipating as much power as the radio.  These are generally not the way
to go for this many amps.
Bruce Roe
jackworstell
Bruce   the factory radio in our 1937 Cadillac is a Wells Gardner 5X.  It has a six pin vibrator  ( equivalent to a Mallory 248 I think )
The vibrator has markings on it to the effect that one position is for negative ground systems and by physically  rotating it 180 degrees
it will work for positive ground systems.   From my somewhat limited understanding of vibrators..... this is a synchronous unit......it provides rectification as well as the source of an oscillating waveform.
So......based on your previous remarks,
            the Wells Gardner 5X radio would be polarity sensitive ??
and....since the vibrator can be flipped 180 degrees.....it this particular instance this radio can be used with either positive ground systems or with negative ground systems ?
Thanks   for the advice....Jack
Quote from: jackworstell on October 04, 2017, 03:03:16 PM
Jack, I didn't know about the 180 degree option, but yes that is going to
be the only polarity sensitive part of the radio.  With a DC-DC converter,
the radio can stay stock (but flipped).
There is another way around this, disconnect the transformer secondary
wires from the vibrator pins and wire in a couple diodes; then the radio
isn't polarity sensitive.  This method could also be used to convert to a 4
prong vibrator if you can't find a good 6, could be wired as an external plug
in to the 6 pin socket.  good luck, Bruce Roe
