clutch release fork clip (years?)
Started by ccp49, October 05, 2017, 12:34:34 AM
ccp49
Hello, all,
I have a clutch fork with a broken clip on the end that attaches to the linkage (not the double end that contacts the release collar.
My clip is broken?  Does anyone have an extra clip they no longer need?   It is going on a '49, but think is the same for many years.
Dan Barbieri
Dan Barbieri
'49 Conv "in the works"
Cedar Rapids, Iowa
ccp49
By the way, the same fork was used from 1940-1953, if that helps any of you all that might be wondering if that rusty part in your garage just might work for me!
Dan Barbieri
Dan Barbieri
Cedar Rapids, Iowa
They will work fine without the clip if you get really stuck, Dan. I have had several cars over the years with the clip broken. I think its just and anti-rattle thing.
ccp49
Good to know, Steve. Thanks.  I was thinking the same thing since there the linkage is a threaded shaft that allows adjusting the linkage throw, and part of the shaft will stick through the hole in the fork.
Best,
Dan
Dan Barbieri
Cedar Rapids, Iowa
