Author Topic: Occasional pop noise under my '41 62  (Read 142 times)
Offline Jim Miller
      CLC Member #30628
  • Name: Jmiller
« on: October 11, 2017, 04:46:05 PM »
Once in a while moving slowly forward I will hear a single pop under the car. Sounds  toward the rear end. Sounds like when you run over a piece of gravel that pops from the edge of the tire or running over a walnut on the street. Usually after shifting from reverse to forward and after traveling 20 or 30 feet - like maneuvering around to get into the garage or pulling out of a parking spot. Checked rear axle nuts and suspension nuts for proper tightening and checked u-joints. Rear bushings and pads are atrophied, but not sure that would do it. Any suggestion of things to check?
Jim Miller
Jim Miller
1941 62 sedan
2016 SRX
Offline The Tassie Devil(le)
  • Administrator
      CLC Member #18992
  • Name: Bruce Reynolds
Re: Occasional pop noise under my '41 62
« Reply #1 on: October 11, 2017, 05:14:14 PM »
Have a look at your universal joints.
Offline V63
  • Name: W Link
« Reply #2 on: October 12, 2017, 07:26:15 AM »
My guess would be bushings..but also could be a brake shoe. Check wheel nuts and studs. Rear Axle fluid level ?
Offline Steve Passmore
  • Name: Steve Passmore
« Reply #3 on: October 12, 2017, 11:18:21 AM »
I would remove all 4 brake drums and check everything. Had some similar noises on my 41, turned out a back brake was sticking in reverse and would suddenly 'pop' off when moving forward.   Both return springs had broken and the broken pieces were jamming up under the lining.
Offline Jim Miller
      CLC Member #30628
  • Name: Jmiller
« Reply #4 on: October 12, 2017, 01:56:30 PM »
Thanks guys - I appreciate the feedback. Recently had all the drums off - shoes, cylinders, and springs were good. I was concerned about the rear drums after reading the forum, but a friend had a very old giant puller and they came off easily. Didn't need a BFH. Re packed front bearings and rear are sealed, but the area was very clean. The rear were Timkens, but I don't know their age. I did order but not put on yet new rear bearings and seals from George at Olcar. Checked u joints when we did the pinion seal. This is why I'm at a loss. It's occasional and I've stopped worrying about it, but it's like an itch you can't scratch.
Jim
Jim Miller
1941 62 sedan
2016 SRX
Offline Bob Schuman
      CLC Member #254
  • Name: Robert Schuman
« Reply #5 on: October 12, 2017, 02:33:33 PM »
Jim,
It looks like Bruce, Steve, and W. Link have covered about everything, but I can suggest one more. Each brake shoe rests against three smooth pad surfaces on the brake backing plate. With wear, those pads can become slightly grooved by the motion of the brake shoes. That can cause slight sticking of the smooth movement of the shoes, and possibly a popping when the shoe overcomes the groove. Checking will require again removing the rear drums, prying the shoes away from the backing plates or maybe removing the shoes to inspect, and grinding those pads smooth if necessary.
The above is a long shot, with my vote still going to a U-joint, even though they have been checked before.
Bob Schuman
Bob Schuman, CLC#254
1949 6237X
1951 6137
1948 Olds 98 Custom
Offline Jim Miller
      CLC Member #30628
  • Name: Jmiller
« Reply #6 on: October 12, 2017, 02:49:26 PM »
Thanks - before the weather turns I think we can tackle the dried up rubber components and that's an opportunity to check the u joints and your brake suggestion.
Jim Miller
1941 62 sedan
2016 SRX
