38 LaSalle Torque specs
Started by Ken, May 01, 2005, 09:44:49 PM
Ken
What is the proper torque specs for the head bolts on a V8 LaSalle? What is the proper sequence?
Thanks, Ken
Ken
Or for that matter ANY torque specs. We cant find any torque specs anywhere in the shop manual.
Thanks, Ken
Wayne Womble
My old Motors Manual states: Rods 50-60, Mains 130-140, Heads, 70-75, and intake,exhaust 25-30. It states  tighten from the center outward  This is common proceedure. Start in the center and work outwards tightening to a lesser torque and working up to the recomended final torque.
JIM CLC # 15000
05-02-05
Ken, I always torque heads and anything else that has more then one bolt/nut, in steps, say one-third of total torque, then two-thirds, then full value.
Cylinder heads installed with a speed-handle or six-eight inch ratchet will be very loose when the torque wrench is applied.
Yes, start in the center and work in a circle, if it will help, draw a diagram of the head and head bolts to work from.
Good Luck, re-torque after running the engine, Jim
