1949 convertible door striker
Started by ccp49, January 29, 2011, 08:47:11 PM
ccp49
Hello, all.
Wondering if anyone knows whether the strike plates (the plate that attaches to the door jamb with two sunken phillips screws) is the same on all doors.  Mine have some wear and so would need to repair before replating.  Or, find some replacements to replate that are not worn.   Thinking I have a better chance finding some rear door strike plates that are usable.
Dan
Dan Barbieri
'49 Conv "in the works"
Cedar Rapids, Iowa
ccp49
And, yes, I realize there is left and right for all models.
Dan Barbieri
Cedar Rapids, Iowa
Jeff Maltby 4194
#2
I have some off a sedan that have little wear . I asked my buddy whom has restored 2 49 Converts and they are the same.
Jeffo 49er chapter
CLC 1985
Honda Gold Wing GL1500
Dan Barbieri
Jeff,
Don't you have a club coupe? If so, can you check to see whether your sedan strike plates are the same as on the CC?  I would bet the Coupe plates are the same as the convertible plates, no?
Dan
cad1949 convertible
Hi rear on a sedan( 4 door), is the same in front of a convertible.
regards Johan Karlsson Sweden.
Johan Karlsson (cad1949 convertible)
