1961 Cadillac Under Steering Column Trip Piece Wanted
Started by 1961CadillacConvertible, November 05, 2014, 12:41:20 PM
I am looking for a trim piece for under the steering column.  It has to be in good serviceable condition.
I have one however the square hole for the top lift switch is the wrong size so one without a hole would be do-able as I can cut in the correct size hole.
Bill
billhuntersemailemail addresses not permitted
Ken Perry
I think I have a extra,let me check and see. Haven't talked to you in a while,hope thing are well with you.  Ken Perry
Cadillac Ken
Hi Ken,
I hope you are doing well.
Did you get a chance to look for this part?
Specifically I am looking for the following:
-Under steering wheel dash trim with no holes (I have a cherry one that has a large square hole in it however the top switch chrome bezel is too narrow to fill the square hole).
-Turn signal cancel switch and mechanism
-Speedometer dash assembly with working speedo and clear lens
THANKS,
Bill
