Author Topic: Scottish 56  (Read 343 times)
Online vwfras
  • Name: Fraser
Scottish 56
« on: October 02, 2017, 05:59:55 AM »
Last August we purchased our first Cadillac and since then haven't had any money  ::)
The 56 sedan has since went through a bare metal respray, floor rebuild, interior make over and engine work. The list of jobs to be done is getting smaller but still plenty to be done.
« Last Edit: October 02, 2017, 06:02:02 AM by vwfras »
F Breingan
Online vwfras
  • Name: Fraser
Re: Scottish 56
« Reply #1 on: October 03, 2017, 01:57:30 PM »
A few more photos of our car going through its build.
Floor had a few holes in it so got my mate to fabricate some new panels. Rear end of the trunk was totally rebuilt too.
After that it went to the bodyshop to get taken right back to the bare metal. Body was really good with the exception of 60yrs worth of dents. All straightened out and a ton of paint put on.
New rubbers and runners from Steele Rubber.
While all this was going on I was on the hunt for two rear bumper ended....never had much luck in my searching and ended up getting the bumper ends repaired. Couldn't have asked for a better job by the guys in Classic Car Chroming in Essex.
« Last Edit: October 03, 2017, 02:02:22 PM by vwfras »
F Breingan
Offline Jeff Rose CLC #28373
  • Name: Jeff Rose
Re: Scottish 56
« Reply #2 on: October 04, 2017, 07:54:06 PM »
Wow, looks great. Keep the pictures coming
CLC #28373
1970 Coupe DeVille
1955 Series 62
Offline James Landi
  • 2007 XLR
      CLC Member #21920
  • Name: James Landi
Re: Scottish 56
« Reply #3 on: October 05, 2017, 04:05:04 PM »
Finding decent  rear bumperettes was nearly impossible 40 years ago!  As you likely already know, the hot exhaust and associated moisture would rot out the interior inserts and then the bumper ends would rot through, replete with the rusting from the inside out.  Another weak point is the front parking light surround that can weaken  and get crushed if the tire jack is used on the front of the car.  I owned two of these short deck '56's with air conditioning, and i absolutely loved them--- they were so quiet and with the tires inflated to factory specs, the car was extraordinarily smooth.  As I recall, several odd engineering issues can cause frustration... the lack of lubrication for the fuel pump (inside mechanical "rocker" arm pivot needs to be packed with grease!)... the windshield wipers that respond to the engine vacuum, the roof mounted a/c ducts that drip condensate on your neck!  Yours is looking so very good... believe me, yours is a worthwhile project.
Online vwfras
  • Name: Fraser
Re: Scottish 56
« Reply #4 on: October 05, 2017, 04:58:53 PM »
Thanks very much guys, Yeh the bumpers ends hit the bank hard but had to be done. Here are some more photos of it going through the repair process. Hats off to the guys in Essex for doing it.
Funny the list of faults you mention I've changed most of them. Went for an electric fuel pump and the previous owner changed it to an electric wiper. Ive taken the compressor out for the air con for now as the pipes underneath were slightly damaged. I've kept everything for the AC so I can refit it one day further down the line but we don't get too many days in Scotland where you need it. Nice feature to have on a car of that age, especially like the pipes up the back window. I also need to adjust the truck pull down as it seems to unlatch itself as it pulls itself down.
F Breingan
Offline The Tassie Devil(le)
  • Administrator
      CLC Member #18992
  • Name: Bruce Reynolds
Re: Scottish 56
« Reply #5 on: October 05, 2017, 05:49:02 PM »
Congratulations on the chrome plater to attempt to get the end re-steeled.
Looks like a real tradesperson tackled the task, and pulled it off beautifully.
Offline carguyblack
  • Name: Chuck Dykstra
Re: Scottish 56
« Reply #6 on: October 05, 2017, 08:28:18 PM »
Unflipping believable on the bumper ends!! Back when I first started on the 1956 Cadillacs (3 so far since 1997), your bumper ends would have been a throw aways here in America. My re-chromer, as good as they are taking out dents and straightening bumpers, would have laughed me out of the office if I brought that to him. Just amazing work your guy did and hats off for resurrecting both that part and the car itself!! Thanks for posting. Am eager to see your finished good work on the car.
Chuck
Chuck Dykstra
1956 Sedan DeVille
1956 Coupe DeVille (2 sold)
1957 Oldsmobile 98 (sold)
1989 Bonneville SSE
Online vwfras
  • Name: Fraser
Re: Scottish 56
« Reply #7 on: October 06, 2017, 06:32:24 AM »
Yeh the guy has talent for sure. Have a few bits that still have to get chromed along the way. Here's there Facebook page.
 https://m.facebook.com/classicCarChroming/?locale2=en_GB
F Breingan
Offline harascho
  • Name: Harald Schoener
Re: Scottish 56
« Reply #8 on: Yesterday at 01:58:53 AM »
Hi Fraser,
nice to see another Europeen '56 Caddy. I am in Germany tackling the same task, a '56 Series 62 Coupe...  lots of rust issues...it was a long way, but finally I got her in primer.
How's your project right now?
cheers
Harald
Online vwfras
  • Name: Fraser
Re: Scottish 56
« Reply #9 on: Today at 04:31:13 AM »
Hi Harald, looks like you've got your hands full with your 56.really like the coupes. Our build had slowed down a bit, the water pump seal had went so we were a few weeks waiting on parts and the engineer shop changing the seals. Etc over. Good job done in the end and it's up and running now. Not using it again until the road salt has cleared.
Next jobs are headlining, exhaust and rear crank seal.
How do you find getting parts in Germany?
F Breingan
Online vwfras
  • Name: Fraser
Re: Scottish 56
« Reply #10 on: Today at 04:38:03 AM »
Some more photos of the our car.
F Breingan
