Author Topic: Speedometer gear for 59  (Read 166 times)
Offline Ed Burke
      CLC Member #30998
  • Name: Ed Burke
« on: November 15, 2017, 03:48:49 PM »
Can't find this in topic search. Having a difficult time finding a plastic 18 tooth speedometer gear for my 59. Any help?
Offline russ austin
  • Name: Russ Austin
Re: Speedometer gear for 59
« Reply #1 on: November 15, 2017, 07:16:41 PM »
I'm out, but 59-64 Hydra Matic non AC cars are the same gear.  2.94 rear end.
R.Austin
Offline Ed Burke
      CLC Member #30998
  • Name: Ed Burke
« Reply #2 on: November 15, 2017, 10:08:06 PM »
This gear cannot be found anywhere!
I attached two photos. This plastic gear I need slips over the metal axel. Everything I find is with a solid plastic axel
« Last Edit: November 15, 2017, 10:11:18 PM by Ed Burke »
Offline brian faull clc#25881
      CLC Member #25881
« Reply #3 on: November 15, 2017, 10:42:45 PM »
I think I have one. If your still looking email me. Thanks, Brian. cadillac32v@hotmail.com
Offline Roger Zimmermann
  • Switzerland
      CLC Member #21015
  • Name: Roger Zimmermann
« Reply #4 on: November 16, 2017, 02:10:56 AM »
That could be maybe done with steel like the pinion for the '56 model. Maybe more noisy, but will never go bad. While overhauling those transmissions, especially '59 & '60, i saw many plastic pinions with stripped tooth.
1957 Eldorado Brougham
1972 Coupe de Ville (not yet arrived)
Offline Ed Burke
      CLC Member #30998
  • Name: Ed Burke
« Reply #5 on: November 16, 2017, 07:30:42 AM »
I will look for one of these
  • Switzerland
      CLC Member #21015
« Reply #6 on: November 16, 2017, 10:30:27 AM »
I was probably misunderstood. A 1956 pinion will probably not fit and the number of teeth is different. You have a 18-teeth pinion for a rear axle 2.94:1 when the pinion for 1956 had 17 teeth for the rear axle 3.07:1
Offline Ed Burke
      CLC Member #30998
  • Name: Ed Burke
« Reply #7 on: November 16, 2017, 12:39:12 PM »
Ok. Thanks. I may have a lead on a plastic one
