Author Topic: Flat spots on radials?  (Read 392 times)
Offline south280
  • Member# 30327
      CLC Member #30327
  • Name: David Sanford
« on: November 24, 2017, 03:20:18 PM »
Hi, is it common to have flat spots on my 1976 Eldorado radial tires after sitting for 6 months without moving?  Has anyone tried using those anti flat spot ramps?  The tires are 8 months old   Thanks
1976 Cadillac Eldorado Bicentennial Edition
1930 Model A Ford Station Wagon
1968 Mercedes 280 sl
Offline Steve Passmore
  • Name: Steve Passmore
Re: Flat spots on radials?
« Reply #1 on: November 24, 2017, 04:07:46 PM »
Not common but that can happen after 6 months. Some say drive it at highway speed for a good distance to get rid of it but that's if you can stand the bumpy ride.    Best to have the car up on stands,
Offline Dave Shepherd
« Reply #2 on: November 24, 2017, 06:20:33 PM »
Lotta weight over those front wheels, inflating to 40 psi and setting the car on 3/8 plywood is what I have doing, cheap attempt to try and stop flat spotting, but it is uncommon with radials vs bias.
Offline collector
  • Name: john rutenberg
« Reply #3 on: November 25, 2017, 12:40:07 PM »
Drive the car the heat will correct your flat spot issues.
Offline TJ Hopland
« Reply #4 on: November 25, 2017, 12:55:41 PM »
Check the date codes and make sure someone didn't sell you tires that have been on the shelf for a few years.   Current tire technology may be better for mileage and traction but seems terrible for lightly driven classic applications.
StPaul/Mpls, MN USA
73 Eldo convert w/FiTech EFI
75 Eldo rusty but trusty
80 Eldo Diesel
Offline James Landi
  • 2007 XLR
      CLC Member #21920
  • Name: James Landi
« Reply #5 on: November 26, 2017, 09:14:17 PM »
The "Flat Free" devices appear to work well, but be careful getting your car on to them, as  your  drive wheels tend to shoot them out from under the car as you torque up the car's engine to get the four wheels  on to them. I needed to get a bit of a "running start" to get all four wheels over the initial hump(s).   Happy day, James
Offline Driver8
  • 1979 Cadillac Seville
  • Name: Mark Allen
« Reply #6 on: November 28, 2017, 10:53:49 AM »
I took my hydraulic floor jack and jacked the car up a bit, then just slid them into position. IMO, much easier than trying to keep them lined up and 'driving' onto them evenly and exactly where they need to be.
mark~
Mark Allen  CLC # 28250
'79 Cadillac Seville  http://bit.ly/1VEbnNo
'15 Chrysler 300s   http://tinypic.com/r/2lntu9z/9
'99 Jeep Grand Cherokee Limited   http://bit.ly/1VE758Q
Offline James Landi
  • 2007 XLR
      CLC Member #21920
  • Name: James Landi
« Reply #7 on: November 28, 2017, 02:37:04 PM »
mark~
Mark-- that's a safe way to do this... a sensible approach.  Thank you for the advice.  James
Offline Driver8
  • Name: Mark Allen
« Reply #8 on: November 28, 2017, 04:06:27 PM »
 No prob James, necessity is the mother of invention/ideas I guess.
i have a very old & small brick garage, there's less than 4" to the door with the Cadillac's rear bumper touching the back wall, with maybe 4-5" on the passenger side before the mirror gets taken off because it's so tight, I also have to turn the wheels and wedge the car in behind the front return wall that supports the door track so I have some space down the center between the Cadillac & the 300.  So, I 'had' to do it this way to not risk an incident with the Cadillac and a brick wall, or two or three.  :)
At any rate, I do think it will work well for everyone no matter how much space they have because they wont go flying somewhere when you hit the gas.  it only takes a few extra minutes, and the pads are always perfectly aligned (which is what you need if you want them to work).
Take care, mark~
Offline gary griffin
  • garygriffin@Q.com
      CLC Member #26430
  • Name: Gary Griffin
« Reply #9 on: November 29, 2017, 03:59:14 PM »
Who sells the flatfree devices and are there different sizes? I could not find them on Google!
Gary Griffin
1942 Cadillac 6719 (parts car) (Gone)
Offline south280
  • Member# 30327
      CLC Member #30327
