Author Topic: Battery For A 1965 Eldorado  (Read 214 times)
Offline AC
  • Name: ACalise
« on: November 25, 2017, 03:31:42 PM »
What do you guys like as a choice for a new battery for my 65 eldo?  Brand,,,, size,,,, where to purchase?
Offline The Tassie Devil(le)
  • Administrator
      CLC Member #18992
  • Name: Bruce Reynolds
Re: Battery For A 1965 Eldorado
« Reply #1 on: November 25, 2017, 04:10:20 PM »
When getting a replacement battery, I measure the total interior dimensions of the battery "box" and go to the Battery Shop, and buy the largest one I can find that will fit.
Plus, these days, with the advancement of battery design, I also go for the best one that will last the longest, with the least maintenance.
Oh, that's right, I am not concerned about originality.
Offline tripwire
      CLC Member #30157
  • Name: Wes Paro
« Reply #2 on: November 25, 2017, 05:08:35 PM »
If you are not concerned about originality, I've heard the Optima AGM batteries get good reports.
And, not that it matters, these batteries tend to be smaller & lighter than the wet cell variety and they last a long time.
WParo in VT
Driving now:
2013 CTS4 Performance Coupe
1940 LaSalle 5229 C4D
A few I used to drive:
1976 Cadillac Ambulance
1969 Cadillac Hearse, Superior Body
1966 Buick Wildcat Hearse
1957 Ford Thunderbird x 3, 1 E code, 2 D code
1956 Oldsmobile Rocket 88 Sedan
1949 Mercury Convertible
1949 Mercury Coupe, Mild Custom
1936 Buick Special Sedan
Offline gene harl
      CLC Member #22406
  • Name: Gene Harl
« Reply #3 on: November 25, 2017, 05:45:47 PM »
the floor in my 59 battery box was rusted out,, so I incrested the sized about 1/2 inch and fitted Optima battery in it.. got it from Amizon.....
  Gene Harl   clc 22406
Offline Scot Minesinger
      CLC Member #20543
« Reply #4 on: November 26, 2017, 07:53:18 AM »
The problem with Optima batteries is that if it drains and requires a charge or jump, you need a special charger.  If you just jump an Optima with another car, say goodbye to that Optima very soon.  I would not use an Optima, they work great until someone uses the power accessories too much with car off and it needs to be jumped...and
Bruce's advise is the way I roll too.
Offline TJ Hopland
« Reply #5 on: November 26, 2017, 09:38:55 AM »
My limited research shows that as a group 27 battery which is still somewhat common so you should not have any issues finding something that will fit correctly unless there was something unique about that model.
What I found says that is 12 x 6 3/4 x 9.   And was used by Cadillac 59-66.
The 34/78 that was the 70's-2000's one was 10 1/4 x 7 1/16 x 7 11/16.     That explains the 1/2 that the others mentioned and why many batteries come with what seems like a safety/stacking grid cover on them that is actually an adapter that snaps on the bottom to gain you that 1/2 of width and inch of height to make it a semi universal fit.   Optima is the only one where that adapter is almost always there because its what also holds the other adapter clamps and such they come with.   I think a lot of stores and people think its packing and throw them away.
StPaul/Mpls, MN USA
73 Eldo convert w/FiTech EFI
75 Eldo rusty but trusty
80 Eldo Diesel
Offline AC
  • Name: ACalise
« Reply #6 on: November 26, 2017, 03:11:11 PM »
Thanks gentlemen,
Great input as usual.
Offline gkhashem
      CLC Member #26576
  • Name: George K Hashem
« Reply #7 on: November 26, 2017, 03:19:47 PM »
The modern AC Delco choice
AC Delco 27PG
Here's one, but you can go to a local GM dealer they can get one.
https://www.ebay.com/i/331926160965?chn=ps&dispctrl=1
« Last Edit: November 26, 2017, 03:21:20 PM by gkhashem »
1959 Cadillac Coupe Deville
1964 Oldsmobile 98 Town Sedan
1966 Cadillac Coupe Deville (Senior #861)
1970 GMC C/K 1500
1978 Cadillac Coupe Deville (Senior Crown #959)
1984 Oldsmobile Delta 88 Royal Brougham Coupe
1989 Buick Reatta
1991 Oldsmobile Toronado Trofeo (OCA 1st)
1991 Cadillac Eldorado Biarritz (Senior #838)
Offline AC
  • Name: ACalise
« Reply #8 on: November 27, 2017, 06:47:00 AM »
Excellent,
Thanks!
