Author Topic: 1968 Eldorado on CL - 00 Paint Code  (Read 898 times)
Offline BJM
« on: November 25, 2017, 08:44:13 PM »
I have been trying to purchase a 68 or 69 Eldorado for a few years. I get close to buying drivers, maybe some projects, then drop out.  This one popped up on my craigs list here in Des Moines for close to crusher price.
This is not a "buy the best car you can" request.  Can someone with more knowledge and resources tell me about the attached VIN plate?
The story on the color was that it was repainted. The seller believes the original paint is dark blue.  We looked everywhere for a sign of dark blue and could not.
It appears to be a mauve or metallic light purple with white top.  The interior is houndstooth. Door panels,dash, etc are in nice condition.
Does SMS sell a correct or near correct Houndstooth clothe to reupholster?
Thanks for your help.  Hope the photos show the V.I.N. plate OK.
« Last Edit: November 26, 2017, 08:23:40 AM by BJM »
Bryan J Moran
CLC # 12994
Des Moines, Iowa
1968 Cadillac Eldorado
Offline BJM
Re: 1968 Eldorado on CL - Can someone decode Tag?
« Reply #1 on: November 25, 2017, 08:48:19 PM »
Let me know if I need to resize smaller.
02C
68-69347     FWD12770    PAINT 00-61
TR     410-
Bryan J Moran
CLC # 12994
Des Moines, Iowa
Offline D.Smith
  • 1961 Sedan deVille
      CLC Member #17592
  • Name: Dave Smith
« Reply #2 on: November 25, 2017, 09:26:56 PM »
02C
TR     410-
02C  means it was made the third week of the second month.
68-69347 is the Eldorado number.
FWD12770 is the body number.  So it was the 12,770 Eldorado made to date.
PAINT 00 means it was painted a non-standard color!   Thus it was a special order.   61 is the white vinyl top color.
TR 410 is the interior which is black/grey Dominion cloth.
The staples on the metal tag are for the instructions for the special order.  That paper would have had the special color listed on it that the car was to be painted.    The current exterior color could very well be the special order color.
« Last Edit: November 25, 2017, 09:41:14 PM by D.Smith »
Offline BJM
« Reply #3 on: November 25, 2017, 09:41:05 PM »
I did a google search and found I believe a website associated with CLC and created by Ralph Messina. I think I recognize that name from forum posts.
He did seem to indicate 00 meant a special order paint.   That actually complicates things a bit, because it must have a code or color name.  I would call it Lavender.  The tag or paper that was attached is obviously long gone and there does not seem to be much paperwork on the car/in the car.
It can't be a one-off.  The reason I felt it was the original color is due to the level of paint coverage. It's everywhere - perfectly painted door jambs and in the trunk.
The car has a dealer tag on the trunk that indicates it was sold in Marshalltown Iowa when new.
« Last Edit: November 25, 2017, 09:46:08 PM by BJM »
Bryan J Moran
CLC # 12994
Des Moines, Iowa
Offline D.Smith
      CLC Member #17592
  • Name: Dave Smith
« Reply #4 on: November 25, 2017, 09:45:27 PM »
Actually it is.    The number 00 means it wasn't a current color offered.  You won't find a record of the color it was painted unfortunately.
So unless it was a multi car fleet order in some special color, it will indeed be a one-off car.
Congrats!   That is a great find!
Online Bob Hoffmann CLC#96
      CLC Member #96
« Reply #5 on: November 25, 2017, 09:51:29 PM »
Dave's correct. That color could be a previous year offering or the color of his wife's drapes. Maybe someone on the board will recognize it.   Maybe 1960 heather??
Try to save it if possible.
 Bob
1941 62 coupe custom maroon
1970 DeVille conv. triple black
Offline BJM
« Reply #6 on: November 26, 2017, 08:21:13 AM »
Refresh me on what would happen at a judged CLC event?   This car would need repainted, and matching that would best be derived from the inner trunk lid.
Bryan J Moran
CLC # 12994
Des Moines, Iowa
Offline J. Skelly
      CLC Member #15958
  • Name: Jim Skelly
Re: 1968 Eldorado on CL - 00 Paint Code
« Reply #7 on: November 26, 2017, 09:14:06 AM »
Bryan,
It's a long shot, but maybe the dealer is still in business AND still has the sales information.  It looks like the 1969 color, Wisteria, but obviously isn't since the car is a year older.  Hopefully you can buy it and get it restored.
Jim Skelly, CLC #15958
1968 Eldorado
1977 Eldorado Biarritz
1971 Eldorado (RIP)
Offline David King (kz78hy)
  • Check out the Eldorado Brougham Chapter
      CLC Member #22014
  • Name: David King
« Reply #8 on: November 26, 2017, 10:20:36 AM »
Buy the build sheet for the car and most likely the paint info will be there.  Cool color on the car.
David King
CLC 22014  (life)
1958 Eldorado Brougham 615
1959 Eldorado Brougham 56
1960 Eldorado Brougham 83
1998 Deville d'Elegance
2003 Deville gifted to daughter
1964 Studebaker Commander
1966 Pontiac GTO convertible
2012 Volt
CLCMRC benefactor 197
Director and Founder, Eldorado Brougham Chapter of the CLC
Past President, Motor City Region of the CLC
Rare Parts brand suspension parts Retailer
Offline D.Smith
      CLC Member #17592
  • Name: Dave Smith
« Reply #9 on: November 26, 2017, 10:25:03 AM »
Don't worry about judging.  That is a moot point at best.   With the "00" paint code it could be any color other than a newer one.
But Special Order cars are, well, special.   So it would be best to repaint it in as close to the original as possible.   And you are right, under the trunk lid is a good place to look.   You can also peel back the trunk lid weather stripping too and see if it is the same color as the inside of the trunk lid.    If that all looks factory then you can bring the car (or just the trunk lid) to a paint supplier and they can scan the inside of the lids surface for the color mix codes.      The scanners are portable and they'll take it out to the car and make the scan.     Once they load the info in their computer, the computer looks for a code mix match with other known older colors in the database.    Then they can offer to mix you paint of that mix.
68 Eldorados are very desired cars today by collectors.  More so than 67s even as many collectors like their refinements of them over the earlier and later years.       Yes that one is rough in some areas, but being a Special ordered color car it will be even more unique to collectors.   To just give it a repaint in a standard color would be an injustice.    Or worse, to see it scrapped.
Offline D.Smith
      CLC Member #17592
  • Name: Dave Smith
« Reply #10 on: November 26, 2017, 10:27:33 AM »
Pretty sure 68 is the one year they don't offer it due to a fire that destroyed the 68 records.
And from the micro film copies of older build sheets they just have columns with code numbers.
It would probably just have the "00" listed.
Maybe someone else can verify this.
Offline BJM
« Reply #11 on: November 26, 2017, 10:35:21 AM »
Thank you for all the information.  I mentioned, I have been looking specifically for a 68 Eldorado for years. I almost settled on a 69 last year and that would have been fine.  I was not interested in the 1970's because of the 500 cid engine.  472 is more than enough.
I have owned 2 67 Eldorados.  I restored a 66 Toronado and owned and drove another 67 Toronado. For me, it's a wash between the two as far as my interest but the Eldorados have a much more refined style and presence.
BUT, because they were hard to find in driver condition, I purchased 3 Buick Reattas in the past 4 months.  One is a nice driver, a 1990 Driftwood (Gold) convertible, the earliest known Reatta left (#105) and a special edition 1988 Select Sixty.
I am a bit out of room and 2 of the Reattas are being restored (they run & drive)
As usual, cars of interest come along at the wrong time.   I will try to buy it (68 Eldorado) and would love to buy the build sheet.  Too bad the records are missing but maybe a build sheet under the rear cushions??
Bryan J Moran
CLC # 12994
Des Moines, Iowa
Offline BJM
« Reply #12 on: November 26, 2017, 10:39:38 AM »
I don't know about the color yet but I have followed Cadillac for a few years. I have owned 2 1941's including a 60S, a 1964 Coupe deVille and so on, so in research I do recall a "Heather" color in the 60's.  Maybe from the convertible Eldorado years?  I'll do some research - but it makes sense that a potential buyer sees a color on an OLDER Cadillac that they "must" have on a new model they like.  They then agree to pay extra to have this car painted in that color.
Cadillac has the paint code information, and it passes muster by harmonizing with the standard black interior, so sure, why not?
Bryan J Moran
CLC # 12994
Des Moines, Iowa
Offline jagbuxx #12944
      CLC Member #12944
« Reply #13 on: November 26, 2017, 10:58:15 AM »
Another possibility could have been the Iris Mist color of 65 Pontiacs? Other GM divisions offered this color under different names in 1965.
The most recent Cadillac color prior to 1968 could have been 1963 Briar Rose or 1962 Laurel or Heather FireMist.
I know that in 1975, the General Manager where I worked ordered his Eldorado demo in 1969 Chevy Hugger Orange.
Definitely an interesting car that should be saved.
Frank Burns #12944
75 Brougham d'Elegance, Emberust Firemist
61 Coupe Deville Bristol Blue
08 STS 3.6 1SC  Thunder Gray
17 BMW 640i Coupe Blue
16 GTI
03 T-Bird Black
17 Tiffin Phaeton 40AH
07 Corvette Blue
"Whatever the occasion, there
is no better way to arrive than in a Cadillac"
Offline Barry M Wheeler #2189
  • Administrator
      CLC Member #2189
  • Name: Barry Wheeler
« Reply #14 on: November 26, 2017, 11:47:48 AM »
In reading the threads, I think you are being a little too cautious. Remember, this IS the Standard of the World. $$$ still talked and often enough, we find cars that do not fit the ordinary mold. If you have the means and space (Your desire comes through quite nicely) I would buy that car and stash it away till you get out of your Reatta binge. (I drove a '67 Toro fifty miles round trip a day for several years and found the only snow it would not go through was a three foot deep drift I got into when the road took a sudden dip. Great car!)
I too remember that shade and thought it was lovely. If SMS does not have that cloth, simply do the whole thing in leather. Getting a car you can (possibly) come out ahead on and like it as well, spells a big plus to me. Buy that sucker!
Barry M. Wheeler #2189
1979 Cadillac Fleetwood Brougham
1981 Cadillac Seville
1991 Cadillac Seville
2016 Cadillac ATS
Offline 2manycars
  • CLC # 30121
      CLC Member #30121
  • Name: Bill Conte
« Reply #15 on: November 26, 2017, 12:45:04 PM »
I'll go along with the others here, on this Eldorado being a special order COPO type car. Def worth saving.
A friend of mine once owned a very nice 1968 Chevelle SS396 that was uniquely equipped. This was in the early 70s. I had not seen it since the mid 70s. That is, until I attended Lead East (a huge 50s show in northern NJ) in 2015 (as I usually did every year). I spotted that car from several rows away, mainly due to the color, and made a bee line for it. I had never seen another Chevelle that color. My friend had not owned it for a long time, but that just HAD to be it.
I got in touch with him that weekend. Yes, it was the actual car. He also told me that the reason I had never seen another one that color was because it was the only one ever built. It carries no paint code. (could it have been coded 00? he did not say). The original owner saw that color and wanted it, and he knew who to ask to get it. The original owner owns it once again, and he was the one who had it at the show. (I did not see him). The car is fully restored now. Some of the interior remains original. Here it is...
Oh, yeah. That is a Cadillac specific color, BTW. Not offered on any Chevrolet.
« Last Edit: November 26, 2017, 12:49:49 PM by 2manycars »
1964 Coupe de Ville
My Current Projects:
1957 Ford Thunderbird
1967 Chevrolet Camaro RS Convertible
My Special One:
2001 Chevrolet Corvette Convertible (bought it new)
Offline BJM
« Reply #16 on: November 26, 2017, 06:29:19 PM »
One of my forum friends on the AACA Forum has a beautiful Wisteria 1969 Eldorado that looks just like this one - only shiny and beautiful.
What if Cadillac painted this one Wisteria in March 1968 to test the paint for the 1969 run?  That would require a 00- paint code yet be otherwise a 'stock' car allocated to the dealer in Marshalltown Iowa.
Bryan J Moran
CLC # 12994
Des Moines, Iowa
      CLC Member #96
« Reply #17 on: November 26, 2017, 06:38:00 PM »
No way!!! You're reading way too much into this situation.
« Last Edit: November 26, 2017, 06:40:10 PM by Bob Hoffmann CLC#96 »
Offline D.Smith
      CLC Member #17592
  • Name: Dave Smith
« Reply #18 on: November 26, 2017, 07:05:55 PM »
Unlikely.     They couldn't keep up with sold orders on the 68 Eldorados.   There was no need to introduce a new color then.    They were selling like hotcakes.  Dealers had back orders.    Nope, this is a special ordered sold car.   Someone must have wanted it the same color as their older model.  Or as someone else pointed out,  Pontiac had a similar Iris color offered in 65.     Someone could have seen an Iris 65 Bonneville somewhere and decided they just had to have it on their new 1968 Eldorado.    So for a few extra dollars and an even longer waiting period they got just what they wanted.
Online Bobby B
  • Mendham, New Jersey
  • Name: Bob Bender
« Reply #19 on: November 26, 2017, 07:25:02 PM »
Bryan,
 You're losing your mind over spending $500.00 for a one-off Eldorado? If you keep rethinking this, you're going to talk yourself right out of it. I can't even buy a set of ashtrays for my car for that price!
                                                      Bobby
1968 Mustang Convertible
1973 Mustang Convertible
1969 Jaguar E-Type Roadster
1971 Datsun 240Z
1979 H-D FLH
