Author Topic: 1939 Cadillac hood brace to hood rubber  (Read 188 times)
Offline brewskiehunter
  • Name: MikeL
« on: November 28, 2017, 03:02:25 PM »
Can anyone tell me if the 39 Cadillac hood brace has any kind of bumper or rubber at the top center where it touches the bottom center of the hood. There is a thin metal plate with two holes overlapping the top of hood brace and I suspect maybe there was a rubber pad or anti-squeak there?  Anyone know?
Offline tturley
      CLC Member #28929
  • Name: Tom Turley
Re: 1939 Cadillac hood brace to hood rubber
« Reply #1 on: November 28, 2017, 07:56:32 PM »
Go to Steele rubber and if it did they will have one
Member # 28929
1940 Lasalle model 5019
1995 Ford F-150
2015 Buick Enclave
Offline Brad Ipsen CLC #737
      CLC Member #737
« Reply #2 on: November 28, 2017, 09:32:55 PM »
Steele doesn't make every piece of rubber for these cars so that is not the finally check.  What model are we talking about here.  At the back center of the hood there is a piece that is not made.  Doesn't seem to be what you are talking about.
Brad Ipsen
1940 Cadillac 60S
1938 Cadillac 9039
1940 Cadillac 6267
1940 LaSalle 5227
1949 Cadillac 6237X
  • Name: MikeL
« Reply #3 on: November 29, 2017, 09:41:39 AM »
Thanks for replying. I have attached a photo of the hood brace with a thin rectangular plate with 4 holes in it. When the hood is down the cowl welt supports the hood sheet metal but when it is raised the hood sheet metal touches this metal plate with the 4 holes. It seems there should be something there as some cushion?
Mike Lewit
Offline Fred Pennington 25635
  • Fred Pennington
      CLC Member #25635
« Reply #4 on: November 29, 2017, 04:49:46 PM »
Brad, I am assuming you mean what appears to be a mounting pad on the rear center of the hood.
I have always wondered what goes there but have never found a photo that showed a bumper.
If you have a photo of what goes there I would like to see if I can make it.
Fred Pennington, CLC 25635
1940, LaSalle 5019 x2
      CLC Member #737
« Reply #5 on: November 29, 2017, 09:15:23 PM »
Fred, Picture attached.  They don't seem to be needed for function on the small series cars but very needed on 38 to 40 large series cars.  If you get the hood adjusted right it hits the cowl without this rubber there.  It fills the gap (almost) between the hood and the cowl so it keeps the hood from going back and hitting the cowl edge.  I tried once to get it made without success and didn't even try Steele.
On the original question here I believe there is a strip of tar paper anti-rattle between the hinge frame and the hood sheet metal.
Brad Ipsen
1940 Cadillac 60S
1938 Cadillac 9039
1940 Cadillac 6267
1940 LaSalle 5227
1949 Cadillac 6237X
  • Name: MikeL
« Reply #6 on: November 29, 2017, 10:48:34 PM »
I appreciate the responses.. Considering the hood is down 99.9% of the time whatever I put here won't see much wear so I will look at glueing in some rubber sheet.
Mike Lewit
  • Fred Pennington
      CLC Member #25635
« Reply #7 on: November 30, 2017, 04:34:30 PM »
Thanks Brad
      CLC Member #737
« Reply #8 on: December 01, 2017, 09:03:26 PM »
Fred,
If you want to tackle the reproduction of this part I have an extra bare metal part so you can see the exact size.  The pictured one is the best one I have ever seen that shows the bulk of the rubber that was molded to it.  I think virtually every car of this vintage is missing this but don't know how many people would care if on or not.
Brad Ipsen
1940 Cadillac 60S
1938 Cadillac 9039
1940 Cadillac 6267
1940 LaSalle 5227
1949 Cadillac 6237X
