Author Topic: Trying to ID a 67 deck lid lock & flipper  (Read 114 times)
Offline Bob Hoffmann CLC#96
      CLC Member #96
« on: November 29, 2017, 05:12:56 PM »
Does anyone have a 67 unit out of a car? I need  front & back pic. & some dimensions. Please send directly to bobscads@comcast.net
Thanks, Bob
1941 62 coupe custom maroon
1970 DeVille conv. triple black
Offline cadillactim
  • Cadillac Tim
Re: Trying to ID a 67 deck lid lock & flipper
« Reply #1 on: November 29, 2017, 08:06:28 PM »
Bob
The 64-67 key lock covers are the same, while 68 is by itself. The easy way to tell the difference between them is the lock key cylinder is easy to remove on the 68, unlike the 64-67 which has the cylinder going inside the pot metal housing.
Tim
Tim Groves
      CLC Member #96
« Reply #2 on: December 03, 2017, 06:43:11 PM »
Hi Tim,
 Finally got some pics of what I have. It's about 2 1/2" point to point. Can you ID it?
 Thanks, Bob
Offline cadillactim
  • Cadillac Tim
« Reply #3 on: December 06, 2017, 08:43:32 AM »
That's a 68. If my memory is correct it will work on 64-67 trunks also, you will just have to use the 68 lock cylinder, as the others won't fit into the 68 housing.
Tim
Tim Groves
