Author Topic: Engine I/D numbers  (Read 175 times)
Offline My Deville
  • Name: Brian Hermansader
Engine I/D numbers
« on: November 29, 2017, 10:21:16 PM »
A friend recently purchased a nice original 1957 Cadillac, upon sorting out his new car I noticed the VIN/ID number normally stamped on the block forward of the R/H cylinder head was blank ie no stamping. My conclusion is this car received a factory replacement engine which was never stamped. Can anybody provide an explanation ?
Offline Glen
      CLC Member #727
  • Name: Glen Houlton
Re: Engine I/D numbers
« Reply #1 on: November 29, 2017, 11:05:23 PM »
I donít know if this applies to the 57 engine, but sometimes the engine number is milled off when the block is machined by a rebuilder.  If the engine number is at the same height as the head gasket it maybe what happened.
Glen Houlton CLC #727
CLCMRC benefactor #104
Offline My Deville
« Reply #2 on: November 29, 2017, 11:39:17 PM »
Thanks Glen,
I also considered this condition however it appears this engine is original and untouched.
Thanks for your insight.
Offline 2manycars
  • CLC # 30121
      CLC Member #30121
  • Name: Bill Conte
« Reply #3 on: November 30, 2017, 07:29:31 AM »
See if you can find casting numbers and dates on the block and heads. This can help narrow down if it's a replacement or not.
1964 Coupe de Ville
My Current Projects:
1957 Ford Thunderbird
1967 Chevrolet Camaro RS Convertible
My Special One:
2001 Chevrolet Corvette Convertible (bought it new)
Offline Dan LeBlanc
  • Administrator
      CLC Member #27657
  • Name: Dan LeBlanc
« Reply #4 on: November 30, 2017, 07:44:03 AM »
Is it possible that for 1957 that the VIN number was stamped just above the oil pan, centred front to back, on the driver's side of the block like the later 390's?
Dan LeBlanc - CLC # 27657
1970 DeVille Convertible
1977 Continental Town Car
Offline Jay Friedman
      CLC Member #3210
« Reply #5 on: November 30, 2017, 11:33:30 AM »
According to my 1955 Master Parts List, when '49 to '55 replacement engines left the factory they did not have a VIN number stamped onto a boss on the block in front of the right cylinder head unless the buyer specified the VIN of the car the engine was intended for.  Therefore, I would think some replacement engines were sold without a VIN.
However, replacement engines always had a "unit number" stamped on a machined flat spot right behind the distributor.  The unit numbers were divided into several different series depending on whether the engine was for a car with air conditioning, power steering, was a commercial chassis and/or other features.  One series of unit numbers was for replacement engines.
I don't know if this is true of '57 engines, but if there are unit numbers in '57, a Master Parts List covering that year may show them and this might answer your question.
1949 Cadillac 6107 Club Coupe
Decatur, Georgia
CLC # 3210
Offline cappy102
      CLC Member #30926
  • Name: Mark Butterworth
« Reply #6 on: November 30, 2017, 12:12:38 PM »
For what it's worth, here is a photo of the engine SN on my '57 Coupe de Ville. The way the paint has chipped away around the numbers, it looks like the stamping might have been done after the engine was painted. Just guessing.
Looks pretty grubby down there, but I'm on it ;)
1957 Cadillac Coupe De Ville
1981 Moto Guzzi V50 Monza
