Author Topic: My DeVille power window just failed.  (Read 308 times)
Offline slowpoke17
      CLC Member #30836
  • Name: John Federico
« on: November 30, 2017, 02:27:42 PM »
I took my 88 coupe to work for one last trip before the dreaded winter storage. After I gave the security guard my ID and tried to roll up the window I heard something break and the window dropped into the door. I can hear the motor spin but no action.  I recently had the roller guide replaced after I bought it, is it possible it was an inferior aftermarket part that broke again? Is it possible the regulator broke? I also noticed on eBay OEM regulators and roller guides. Am I better off buying NOS parts that are just as old as the car or some less expensive new after market part with possible inferior quality?
Thankfully it was mid fifties and driving home with the window down wasn't too bad. I haven't had a chance to remove the door panel and see what actually broke. This weekend I hope to get in there. Thanks in advance.
CURRENT ENJOYMENT:
1988 Coupe DeVille
2001 Corvette convertible
PAST TREASURES:
1965 Calais coupe
1985 Eldorado
1990 Fleetwood sedan
2005 DeVille
2006 DTS
2013 SRX
Offline 1976Deville
  • Name: H Wandt
Re: My DeVille power window just failed.
« Reply #1 on: November 30, 2017, 09:14:47 PM »
I bought aftermarket roller from Pep Boys . I never had any problem
Offline The Tassie Devil(le)
  • Administrator
      CLC Member #18992
  • Name: Bruce Reynolds
« Reply #2 on: November 30, 2017, 09:38:25 PM »
I turned up my own in my lathe as there is no Pep Boys down here.
Offline jaxops
  • Mark Monaghan
      CLC Member #24591
« Reply #3 on: December 01, 2017, 07:36:59 AM »
Welcome to plastic-world.  Either the motor gear broke or the regulator.  Parts are cheap but labor is not to replace.  Some of these parts are pop-riveted instead of bolted so be prepared if you tackle it yourself.  Watch you arm and hands too- the door edges in the access area are very sharp.
1989 Ford Crown Victoria Station Wagon
1997 Lincoln Town Car
Offline Barry M Wheeler #2189
  • Administrator
      CLC Member #2189
  • Name: Barry Wheeler
« Reply #4 on: December 01, 2017, 07:42:54 AM »
I had to do both fronts on my '81 Seville and don't use the windows much on any of my cars any more than I have to since they are all at risk. And I guess use hasn't got much to do with it either, or with the care you give your cars at all. If they fracture, they simply fall down. Best of luck.
Barry M. Wheeler #2189
1979 Cadillac Fleetwood Brougham
1981 Cadillac Seville
1991 Cadillac Seville
2016 Cadillac ATS
Offline Glen
      CLC Member #727
  • Name: Glen Houlton
« Reply #5 on: December 01, 2017, 10:55:03 PM »
Is this window lift like the old 60ís era scissors mechanism or the newer cable lift?
I had to replace the clamps on the windows for a 2002 Buick.  The plastic clamps are available online.
Glen Houlton CLC #727
CLCMRC benefactor #104
Offline cadillacmike68
  • Still finishing up this 1968
      CLC Member #15823
  • Name: M Santos
« Reply #6 on: December 02, 2017, 01:24:30 AM »
My 1996 is a scissors lift. The thing that cracks is a little white channel guide that sits in the regulator channel and the motor arm is pressed into the center hole. It's quite contorted - under constant stress - so it eventually cracks and down she goes. Same with my 2000 ElDorado Convertible. That one broke while I was in afghan and my wife had to stuff a brick under it to keep the window up until I got back almost a year later.
"Cadillac" Mike
Current:
1968 DeVille Convertible
1996 Fleetwood Brougham
2009 STS NorthStar Platinum ed RWD
2011 CTS PRemiun ed Sedan RWD
Past:
2008 CTS Premium ed Sedan AWD
2005 CTS Hi-Feature Sedan RWD
2000 ElDorado ESC Hard Boot Convertible
1995 Fleetwood Brougham
1973 Sedan DeVille
1970 Fleetwood Brougham
1969 DeVille Convertible
Offline slowpoke17
      CLC Member #30836
« Reply #7 on: December 06, 2017, 03:01:42 PM »
Finally had a chance over the weekend to take my door panel off. I found what looks like a small rounded pin with what looks like a broken metal bracket on the bottom of the door. Thanks for tipping me in advance regarding the metal edges, I can see how you can get all nicked up going in there. I saw the white plastic guides for sale but there was no mention of the pin. As mine is all broken can someone tell me if this pin was part of the regulator or the guide? I'll keep trying to find a drawing of it in my service manual as well. Thanks.
CURRENT ENJOYMENT:
1988 Coupe DeVille
PAST TREASURES:
1965 Calais coupe
1985 Eldorado
2005 DeVille
2006 DTS
2013 SRX
