Author Topic: 1960 fleetwood ac/heater vents  (Read 156 times)
Offline 60kaddydaddy
  • Name: j blasco
« on: December 01, 2017, 09:18:51 AM »
Canít seem to get air to blow out thru the vents or the ac middle cent.Any suggestions?
Offline Dan LeBlanc
  • Administrator
      CLC Member #27657
  • Name: Dan LeBlanc
Re: 1960 fleetwood ac/heater vents
« Reply #1 on: December 01, 2017, 12:15:01 PM »
Yup.  Leaking vacuum pod will not open the door to admit air into the cabin.
Dan LeBlanc - CLC # 27657
1970 DeVille Convertible
1977 Continental Town Car
  • Name: j blasco
« Reply #2 on: December 01, 2017, 01:07:24 PM »
Thanks. Would those be the pods located on firewall or are there some under dash.
Offline Dan LeBlanc
  • Administrator
      CLC Member #27657
  • Name: Dan LeBlanc
« Reply #3 on: December 01, 2017, 01:16:55 PM »
They are all on the heater/ac cases on the firewall.  I believe one on the bottom is best accessed from beneath the car.
  • Name: j blasco
« Reply #4 on: December 01, 2017, 01:32:26 PM »
I do have a slight hissing coming from under dash on driver side when car is running. Would this have something to do with it?
Offline Dan LeBlanc
  • Administrator
      CLC Member #27657
  • Name: Dan LeBlanc
« Reply #5 on: December 01, 2017, 02:03:08 PM »
Possibly, but that could also be automatic parking brake release or neutral safety switch as well.
  • Name: j blasco
« Reply #6 on: December 01, 2017, 02:57:08 PM »
Can the pods be bought and replaced?How do you know if one is bad. Thanks for all the info
Offline Dan LeBlanc
  • Administrator
      CLC Member #27657
  • Name: Dan LeBlanc
« Reply #7 on: December 02, 2017, 06:25:31 PM »
Old Air Products has them new and they are best tested with a vacuum pump (one of those little hand operated ones)
