'76 Seville blower motor
Started by 76Caddy, December 05, 2017, 11:59:31 AM
76Caddy
Has anyone replaced the blower motor on the first gen. Sevilles?  None of my manuals or books mention removing the fender or inner fender but I don't think it is possible without removing at least part of the inner fender.
Tim Plummer
CLC #18948
1967 Eldorado
1976 Brougham
1976 Seville
2019 XT5
1969 Chevy c/10 pickup
1971 Chevy Impala
Has it failed, or just squeaking?  For the latter, some oil on the front and
rear bearings is a cure.  I added oiling holes or extension tubes when
needed for access to my blowers.  Be careful, "replacements" not from
the General will most likely be inferior in performance.
A car here required cutting a hole in the inner fender to get at the blower.
good luck, Bruce Roe
76Caddy
Thanks Bruce.  I do have a NOS one I bought years ago when I had my Sedan deVille.  Right now it is just squeaking when first turned on then quiets down.
Tim Plummer
CLC #18948
1967 Eldorado
1976 Brougham
1976 Seville
2019 XT5
1971 Chevy Impala
I don't know that car specifically but many times its not too difficult to pull the inner fender wells for access to such things.
76Caddy
Tim Plummer
CLC #18948
1967 Eldorado
1976 Brougham
1976 Seville
2019 XT5
1971 Chevy Impala
