Author Topic: '58 horn contact/grommet/wire  (Read 148 times)
Offline 58K114323
  • Name: J. Salchert
« on: December 05, 2017, 03:46:45 PM »
Hi all,
after 58K114323 has found her way to Europe being restored to acceptable state, I have worked up to horn ring function meanwhile. It seems that some day all of the parts running through the steering column were ripped out and dumped: the horn contact, the grommet and the ground wire as well.
I have found a 4-yrs-old thread (http://forums.cadillaclasalleclub.org/index.php?topic=124248.0) that together with the scarce pictures in the Master Parts List told me what was missing. I think I have to make these parts on my own since there seems to be no repro for them, so I might need some help if available:
- does someone have the exact sizing of the horn contact (diameter/height) and the grommet (ID/OD) available?
- where has the ground wire been attached to at its lower end? Steering gear maybe? Frame?
To me it looks like all these parts are sitting in the rotating part of the column, so I assume the parts should not be manufactured to snug fit, right? Think they would always twist the wire when rotating the wheel.
Thanks for sharing ideas - good to have a knowledgeable community like yours :-)
Greetings from Europe
Josef S.
Offline J. Gomez
      CLC Member #23082
  • Name: J. Gomez
Re: '58 horn contact/grommet/wire
« Reply #1 on: December 05, 2017, 05:16:15 PM »
Josef,
Correct the plastic/composite insulator fit inside the steering column with a slight clearance and as do the brass contact inside it. The spring inside the horn ring applies pressure so there is no rotation of either the insulator and/or contact that could twist the wire, the spring rides around the collar on the brass contact.
Unfortunately I closed mine over the weekend so I would not be able to provide the brass tip dimensions.  :(  Maybe someone can chime in.
The wire goes inside the steering column and exits about 1/3 length where the NSS (neutral safety switch) is mounted, there is a brass ring which is mounted on the steering column for the NSS horn contact to ride.
If you do a search on the forum for 1956/1958 horn you will find several post related to this topic.
Hope this helps..!
Good luck..!
J. Gomez
CLC #23082
Time is irrelevant when you work on your classic car, eventually you will enjoy it..!
Offline 58K114323
  • Name: J. Salchert
« Reply #2 on: December 06, 2017, 03:10:11 PM »
Jay, thanks a lot. Think that will help for a first go. Sizings would have been perfect, but I'll try on my own then. Certainly more questions to come on those particular technical solutions Caddys & other cars had at that time... ;) Won't surrender  ;D.
Best
JS
Offline marty55cdv
  • "Life" It's one Cadillac after another
      CLC Member #22760
  • Name: Marty Smith
« Reply #3 on: December 06, 2017, 04:58:45 PM »
 Josef, you can get the contact from Mcveys
Marty Smith
  CLC #22760
41 60 Special http://bit.ly/1Wm0GvT
55 CDV http://bit.ly/1G933IY
1958 Extended Deck http://bit.ly/1NPYhGC
1959 Fleetwood  http://bit.ly/1OFsrOE
63 Fleetwood http://bit.ly/1iSz17J
1964 Eldorado http://bit.ly/1Wm17GA
1988 EBC http://bit.ly/1iSACKz
Offline 58K114323
  • Name: J. Salchert
« Reply #4 on: December 07, 2017, 05:47:12 AM »
WOW! True! It was not listed in the online shop, and the part is available for '57 and '59 only - the '57 part was the same, right? Don't have my MPL available today.
Josef
Offline J. Gomez
      CLC Member #23082
  • Name: J. Gomez
« Reply #5 on: December 07, 2017, 05:54:29 AM »
Josef
The MPL shows the same contact part for '52-'59  ;)
J. Gomez
CLC #23082
Offline 58K114323
  • Name: J. Salchert
« Reply #6 on: December 11, 2017, 02:42:27 PM »
Folks, didn't say thank you up to today, sorry.  :-\
Have ordered repros from McVey's, will arrive this week. Will keep you posted :-)
Best regards
JS
