Author Topic: Need a source for a speedo cable retainig ring in dash - 1968 DeVille  (Read 85 times)
Online cadillacmike68
  • Still finishing up this 1968
      CLC Member #15823
  • Name: M Santos
OK, I need that snap ring or "Wave Washer" as it is referred to on page 12-51 note 53 in the 1968 Shop Manual. The spring is described on page 12-43 and 12-44 of the 1969 manual. Same cable, slightly different attachment, but a 69-70 might work. The cable itself (w/o cruise but mine has the same end that goes into the instrument cluster) is supposed to be the same from 1959 thru 1986, so a 1969 retaining ring should work.
Why would I need this?
Well, the repair shop, in an inexcusable bit of careless not paying attention got the upper cable (from cruise control thru the firewall to dash) snagged when reinstalling the block and basically yanked the cable off the speedometer head, breaking the "wave washer" in the process. The entire dashboard is apart at present and we're trying to find another snap ring / wave washer.
« Last Edit: December 06, 2017, 09:50:07 PM by cadillacmike68 »
"Cadillac" Mike
Current:
1968 DeVille Convertible
1996 Fleetwood Brougham
2009 STS NorthStar Platinum ed RWD
2011 CTS PRemiun ed Sedan RWD
Past:
2008 CTS Premium ed Sedan AWD
2005 CTS Hi-Feature Sedan RWD
2000 ElDorado ESC Hard Boot Convertible
1995 Fleetwood Brougham
1973 Sedan DeVille
1970 Fleetwood Brougham
1969 DeVille Convertible
Offline chrisntam
  • Dallas, Texas
      CLC Member #29206
  • Name: C. Jessen
Re: Need a source for a speedo caple retainig ring in dash - 1968 DeVille
« Reply #1 on: December 06, 2017, 09:22:43 PM »
They must have yanked the Ess out of that cable to break that washer.
I have a cluster in the garage, I'll have a look at it.  I "think" it is part of the cluster....
Be back in a moment.
1970 Deville Convertible  MTS 507
Dallas, Texas
Offline The Tassie Devil(le)
  • Administrator
      CLC Member #18992
  • Name: Bruce Reynolds
« Reply #2 on: December 06, 2017, 09:25:11 PM »
If the one on a 1972 Cadillac is the same, then I can assist if you cannot find one closer.
I would be really checking the speedo itself to ensure that damage hasn't been done to the housing during the destruction.   These things weren't designed to be yanked apart.
Offline chrisntam
  • Dallas, Texas
      CLC Member #29206
  • Name: C. Jessen
« Reply #3 on: December 06, 2017, 09:45:45 PM »
here's a pic or two.  Not sure how it comes off....
Any idea Bruce?
« Last Edit: December 06, 2017, 09:51:48 PM by chrisntam »
Dallas, Texas
      CLC Member #15823
  • Name: M Santos
« Reply #4 on: December 06, 2017, 09:46:28 PM »
Only half the washer is still there. I thought that one tab had been broken off but it's some sort of split ring design and only half of it is left.
I did find a 1967 dash and it has the ring. Looks like it does not want to come off. I'll bring the cluster to them tomorrow.
We can fit the cable and spin it to ensure the speedo and odo are working. Maybe I should make then spin 20 miles on it, the distance I had to drive to get home and back to them.
On the plus side the engine is running quite smoothly and appears to be much more responsive then before. It really  moves out now.
"Cadillac" Mike
Current:
Past:
1973 Sedan DeVille
      CLC Member #15823
  • Name: M Santos
« Reply #5 on: December 06, 2017, 09:49:01 PM »
Chris, that's the 1969-76 version. Its the same as most bowtie cars and lots of folks have it. It can probably be made to fit the 67-68s but since I have one on this old 67 dash I'll use it.  Doesn't make me any less pia'd off.
If this one breaks, there's always jb weld or super glue.  :P
« Last Edit: December 06, 2017, 09:50:55 PM by cadillacmike68 »
"Cadillac" Mike
Current:
Past:
1973 Sedan DeVille
      CLC Member #15823
  • Name: M Santos
Re: Need a source for a speedo cable retainig ring in dash - 1968 DeVille
« Reply #6 on: December 06, 2017, 09:52:52 PM »
Anyone know how to get the transmission shift pointer disconnected. We got the cluster off by carefully sliding it up, but getting it back down will be difficult if that pointer is attached.
The manual says there is an allen screw in a slot.  Real helpful. It also said to remove the radio - NOT NECESSARY!!!
"Cadillac" Mike
Current:
Past:
1973 Sedan DeVille
Offline chrisntam
  • Dallas, Texas
      CLC Member #29206
  • Name: C. Jessen
« Reply #7 on: December 06, 2017, 10:01:41 PM »
Study that washer before trying to remove it.  Please don't break it.
Perhaps remove the broken one first to see how it comes off...
Dallas, Texas
      CLC Member #15823
  • Name: M Santos
« Reply #8 on: December 06, 2017, 10:53:34 PM »
The broken one came off without too much of a fuss.
it's basically a figure 8 loop bent together that wants to spread outward thus making the effective inside diameter smaller to grip the shaft of the speedo expedition behind the cluster. By squeezing the two halves together the effective opening size should increase enough to get the ring to come off the shaft and then go on to my cluster.
"Cadillac" Mike
Current:
Past:
1973 Sedan DeVille
  • Administrator
      CLC Member #18992
« Reply #9 on: December 06, 2017, 11:25:31 PM »
This is the back of the '71 to '73 Speedo.
To remove it you have to remove the speedo from the plastic housing.
As for the Gear Shift Needle, this is got to by removing the under cover from the dash, and looking up at the steering column.
