1957 Hub & Drum (compatibility) question
Started by Acmemopars, February 10, 2018, 11:29:24 PM
Acmemopars
My 57 Eldo (parked since 79) is finally on the road and I'm slowly resolving all the issues one by one.
The driver's side FRONT brake drum was warped due to (what appears to be) the PO hammering installing new wheel studs.
It was seized and unable to roll if the lug nuts were torqued where they should be, but I pulled it off and straightened it out "pretty good", at least enough to drive around town without issues.  The problem is that it makes a little noise while rolling, especially while braking and turning.
I'd rather buy a new pair of front brake drums and possibly new hub/bearing assembly while I'm at it.
Is the 57 drum and hub assembly one year only or will the interchange with other years ?
What is the best source to find a quality set ?
Thank You
Mike Nelson
Denison, Tx
Mike Nelson
Denison, Tx
CLC# 31194
57 Eldo Survivor
70 Sunroof Charger 1 of 1
56 F100
gene harl
Hi,,  I have a set of 56 drums hubs and backing plates ,, they look ready to install... you can have them for the price of packing and shipping from  Fallon, Nv. 89406....  they won't fit my 59..
     Gene Harl    CLC22406
Bobby B
Quote from: Acmemopars on February 10, 2018, 11:29:24 PM
Take Gene up on his offer before you lock up your front brakes. You'll never get it back to normal. Good Luck!
        Bobby
1968 Mustang Convertible
1973 Mustang Convertible
1969 Jaguar E-Type Roadster
1971 Datsun 240Z
1979 H-D FLH
Acmemopars
Quote from: gene harl on February 11, 2018, 01:34:38 PM
     Gene Harl    CLC22406
Sending you a PM...
Thank You
Mike Nelson
Denison, Tx
CLC# 31194
57 Eldo Survivor
56 F100
Bob Hoffmann CLC#96
Guys,
I suggest you check the interchanges before you start sending heavy parts around the country.
Bob
jmurrayent
Yes, I'm not an expert on 57's, but I think 57-59 are the same, but not 56......
J. Allen Murray
1950 62 Convertible
1952 62 Coupe
(3) 1953 62 Coupes
1954 Eldorado
1965 Deville Convertible
1970 Deville Convertible
Many 50-53 coupe and sedan parts and cars
Unfortunately, the hub and drum are specific for 1957, but 58 to 59 Serie 75 & CC used the same assembly. 1958 and 59 drum & hubs have different wheel bearings.
