WTB: 37, 38, 39 or 40 Small Series Interior Sun Visor
Started by Brad Ipsen CLC #737, October 01, 2015, 10:14:45 PM
Brad Ipsen CLC #737
The chrome hinge part is the only part I really need but will buy complete sun visor if necessary.
Brad Ipsen
1940 Cadillac 60S
1938 Cadillac 9039
1940 Cadillac 6267
1940 LaSalle 5227
1949 Cadillac 6237X
1940 Cadillac 60S Limo
Can you show a picture of what your looking for Brad?
1937 LaSalle coupe
 Brad, these parts are rights and lefts. Which side do you need ? John Lehman ... CLC# 26365...
Barry M Wheeler #2189
Brad, I can't go outside as yet as I'm waiting on a FedEx shipment that needs a signature. As soon as he comes, I'll go out and check. The "paddle" portion is "broken" but the attaching items you need should be OK. The one you need has the "thumb screw" chrome doodie on it, right?
Barry M. Wheeler #2189
1981 Cadillac Seville
1991 Cadillac Seville
Brad Ipsen CLC #737
I'll get a picture shortly but it is the style that has the small screw on it that tightens up on the rod on the sun visor itself.  I would really like both sides but left base is needed for sure.  If the other part that rotates is left and right which I believe it is to get the screw facing the right way I need a right for that part.  These two parts are not meant to come apart but for chroming etc. they need to be separated.  Not sure what you mean by the thumbwheel Barry.  It is a standard screw that tightens up on it.  41 and newer have a different spacing on the base screws and the other parts are bigger also.
Brad Ipsen
1940 Cadillac 60S
1938 Cadillac 9039
1940 Cadillac 6267
1940 LaSalle 5227
1949 Cadillac 6237X
I checked when I went out to mow the grass, and it's probably a '41 and has the straight knob to tighten/untighten. Also, the base is broken off. Sorry.
Brad Ipsen CLC #737
Here is a picture of what I am looking for.
Brad Ipsen
1940 Cadillac 60S
1938 Cadillac 9039
1940 Cadillac 6267
1940 LaSalle 5227
1949 Cadillac 6237X
Quote from: Brad Ipsen CLC #737 on October 02, 2015, 10:24:01 PM
I'  Not sure what you mean by the thumbwheel Barry.  It is a standard screw that tightens up on it.  41 and newer have a different spacing on the base screws and the other parts are bigger also.
The thumb wheel that Barry refers to Brad is 41 on and the visor can be unscrewed and pulled towards the centre of the car on its shaft if needed.   Can you show what the screw spacing are?
Brad Ipsen CLC #737
the screw center to center on the longest leg is 1.375 inches and the other two are equal at 1.2 inches.
Brad Ipsen
1940 Cadillac 60S
1938 Cadillac 9039
1940 Cadillac 6267
1940 LaSalle 5227
1949 Cadillac 6237X
Sorry Brad, the one I found has much larger centres so must be for 41.
