1959 engine parts needed BADLY
Started by BIGTOM, October 07, 2015, 04:02:04 PM
BIGTOM
Howdy all,
I've finally gotten to a place where I can get my 59 coupe de ville restored only to find out that I'm missing some parts AHHHH!!! I've not posted in a while bc the project was at a standstill due to my resto guy's business not working out. Now I've got the car at a shop and I need the following:
Drive plate. Disk shaped part that connects the engine and transmission.
Rear engine support
Rear transmission crossmember/support
Bracket for front engine mount
The body is off the frame and I'll likely need more parts etc. so I'm very much in need to lean on some folks who can help/provide resources. The engine is the 390 and I'm also not sure if some of these parts are interchangeable with other years.
Thanks in advance!
Big Fins
There is no rear engine support. This is handled by the transmission mount.
No front mount that I remember, just the two motor mounts that attach the block to the frame.
The whole set up is only on a 3 point mounting configuration.
Current:
Past and much missed:
1977 Brougham de Elegance
1972 Fleetwood Brougham
1971 Sedan de Ville
1970 de Ville Convertible
1969 Fleetwood Brougham
1969 Sedan de Ville
1959 Sedan deVille
Ken Perry
Cadillac Ken
David King (kz78hy)
I have lots of the transmission cross members.  These were off Eldorado Brougham's 57/58.  P/N 1464800 and by the parts book Brougham only.  The rest show common P/N from 57 to 60.
David
David King
CLC 22014  (life)
1958 Eldorado Brougham 615
1998 Deville d'Elegance
1955 Eldorado #277
1964 Studebaker Commander
2012 Volt
CLCMRC benefactor 197
I have the rear crossmember and the rear Trans mount.
Also have an extra set of motor mounts.
As stated there are side motor mounts, one per side and a rear Trans mount and that's it.
No front or rear support.
