WTB '59-'60 trunk edge and 2 dr. quarter window clips
Started by David Greenburg, July 13, 2014, 04:41:14 AM
David Greenburg
I'm looking for:
1.  the large rectangular clips with "legs" used to attach the rear edge trunk trim (there are two types; 4 that receive a stud and 2, used on the ends, that receive a small sheet metal screw).  I could use the 2 ends plus 3 of the others;
2.  the little metal retaining rings that go on the ends of the pins on the "ELDORADO" letters on the '60 trunk (probably used on other lettering on other models as well).  I could use 6 of these; and
3.  the clips (1 per side) used to attach the rear quarter window reveal molding (the stainless "windowsill") on '59-'60 2-doors. I need one for each side; one is broken and one is rusty.
I've attached pix of the parts I'm referring to.   Haven't seen these listed new anywhere, but I'm interested if you have solid used ones.
David Greenburg
'60 Eldorado Seville
'61 Fleetwood Sixty Special
brian faull clc#25881
David, I think I have a few good clips. I will check. Thanks, Brian. 412 952 6027.
David Greenburg
Brian:
Thanks for looking. You can email me directly at finzrfun59 "at" comcast.net.
David Greenburg
