Throttle Lever 67 Cadillac - CAN'T FIND ANYWHERE!
Started by 67restore, October 20, 2014, 06:23:50 PM
67restore
Hi,
I have been searching for a very long time now for a (Primary) Throttle Lever that mounts on a Autoline C 9058 carburetor. I believe it may be interchangeable with the Throttle Lever found on the Rochestor Qudrajet. ANY help would be much appreciated.
Thanks in advance.
Paul
cadillactim
Are you needing the piece that is held on by screws on the carb that the throttle rod connects to?
Tim
Tim Groves
60eldo
Jon. Kluczynski
