1975 or 1976 Cadillac Fuel Economy Indicator Switch
Started by EAM 17806, March 28, 2008, 09:59:00 PM
EAM 17806
HI GUYS:  I'm looking for a NOS fuel economy indicator switch for a 1975-1976 Cadillac de Ville but I do think it is the same part for all the caddys in those years including the Sevilles. I had my ad in E-Bay a while ago but to no avail; finally I found one through Hemmings from a fellow out in California.  I would prefer a new one if available because I have been through about five used ones and they could not do everything it was suppose to do.  So, if any you guys out there in the world know where I can find one I would appreciate it.  THANKS GUYS!  EAM
Claiborne Holmes
jagbuxx #12944
#2
The fuel economy vacuum switches all look the same from 1975-80 but the part numbers varied over the years and the colors of the housings changed. The 75-76 (non Seville) were white with pt# 1607264. Other colors were blue and yellow.
other pt#'s were1608500, 1613879, 1616252, 1613886 depending on year and model.
The vacuum diaphragm inside is what usually fails.
Frank Burns #12944
61 Coupe Deville Bristol Blue
41 Series 61 Deluxe Coupe 6127D Black
08 STS 3.6 1SC  Thunder Gray
16 GTI Gray
03 T-Bird Black
19 Tiffin Phaeton 40AH
07 Corvette Blue
20 MB S450 White
"Whatever the occasion, there
is no better way to arrive than in a Cadillac.
PelleS
Does anyone know where this fuel economy vacuum switch is located on a 1976 Cadillac Fleetwood?
jagbuxx #12944
It is mounted on the firewall, pretty much dead center. Has a vacuum line and an electrical connectors on it.
Frank Burns #12944
16 GTI Gray
03 T-Bird Black
07 Corvette Blue
20 MB S450 White
