1975 Eldorado Convertible - Floor Pans needed
Started by billbrod, July 02, 2008, 10:13:50 PM
billbrod
I need both front and rear seat floor pans.  I am located in Central NY.  315-427-5866
Bill Brod
Ted in Olympia WA
Just to let you know the convert is the same as the coupe.  Also I know 74 to 78 are the same and I bet 71-78 are also.  75-78 tend to rust out over the cat.  They are hard to remove and expensive to ship.
TED
billbrod
#2
Ted
Thanks for the reply.  I was not aware they are all the same for those years and models.  You are right on about the rusting out over the cat converter!  I have a hole 12" in dia. there.
Bill
