My 1940 LaSalle convertible coupe restoration pictures, documents & parts list
Started by Jim Beard, July 09, 2010, 11:29:53 AM
Wayne Womble 12210
There is no way that engine is going to have enough compression and run anywhere near the conditions that would require SS valves or leaded gas.
Jim Beard
Thats what I thought too about the SS valves but the TEL helps if you have ethanol in your gas.
Jim Beard
Just got my new stainless brake lines and my stainless reproduction handbrake cables from inline tube. They did a very nice job on making the new handbrake cables, they are perfect. The stainless hard lines are an exact fit also. They had a quick turnaround time, about 3 weeks and were very good to work with. I would definitely recommend them.
Jim Beard
markl
Jim,
You've solved a huge problem for me.  I didn't have any idea where to turn for reproduction brake cables.
A couple of questions : Do they reuse any of the original hardware?  Is there any one in particular that you dealt w/ at In-line tube?  I'd almost want to ask them for another set just like yours, except my car is the 4-door version, and a 37 rather than a 40, so I bet the length is different (longer, no doubt).
Anyhow, mine are a rusty mess, and I will want new and this fits the bill.
Mark Lowery, CLC#25216
Jim Beard
Mark,
    I dealt with a guy named Don at Inline Tube, 1-800-385-9452, he was very helpful and stayed on top of things. I sent them the rusty originals I had and they copied them and used stainless cable so it will never rust. It cost a little under $200 with shipping both ways for the 3 cables but they do a great job, it is worth it. They used some of the original hardware but they sandblast it and repaint the pieces so they look new. My car is a 123" wheelbase but I would send in your originals for a correct copy.
C.R. Patton II
Hello Jim. Words cannot express my appreciation for your unselfishness in sharing your adventure with our club. Your car is shaping up to be a model for the rest of us to emulate. The challenges that a restoration present can range from the joy of a CLC Grand National award to early balding. It must be fantastic to participate in a livelihood that brings so much beauty and personal satisfaction. You are an asset to our organization. I wish I could go to work to have fun transforming my car to resemble its original Fort street condition. I have the last LaSalle C4D from 1939. I have an advisor/mentor Matt Larson and buddy named Gerry Karasinski, who recently did a magnificent restoration job on a 1941Cadillac 6267D CCP. I took the easy way out since I'm  already bald.
Gary H
Jim,
I had a good time at your shop this morning. Thanks for showing me around, and the work that you are doing. See you out this summer. Gary H. - 39 Cad
Jim Beard
In the process of doing my rear differential I found this info on replacing the pinion seal that I believe was written by Brad Ipsen:
Removal and Installation of Rear Axle Pinion Oil Seal â€" 1937 to 1952
1.   Drain oil from the rear axle.
2.   Remove both rear wheels and brake drums.  This is to eliminate brake drag when measuring the preload torque on the pinion bearings.  As an alternate, back off on the brake adjustment to eliminate all drag.
3.   Disconnect rear universal joint and optionally remove front so entire drive shaft can be removed.  This is to get it out of the way for work to come.
4.   Using a socket and adapters to go from the nut holding the yoke to a 50 inch-lb. (repeat inch-lb) torque wrench measure the resistance of the pinion shaft to rotation.  Do not count the initial load to start the motion.  One expects to see a reading of 10 to 20 inch-lbs.  Note this value.
5.   Mark the yoke location on the pinion shaft with a punch so it can be installed in the original location.
6.   The yoke nut is staked.  Remove as much of the stake as possible.  As the nut is removed the staking will damage the threads of the nut.
7.   Remove nut with an impact wrench.  Use a 7/8 â€" 14 UNF tap to clean up the threads in the nut.  It is important to have clean threads so a proper torque reading can be obtained later.
8.   Remove yoke.  To remove the seal first tap the seal toward the rear in the seal retainer (size adapter).  This will expose a lip on the retainer that a typical slide hammer can catch.  Using the slide hammer remove the seal retainer with seal.  On the bench carefully remove the old seal from the retainer.
9.   In a running change mid year in 1952 Cadillac eliminated the seal retainer design and used a seal with the same ID as the early seals and the same OD as the seal retainer.  Due to the relationship of the seal housing to shaft these will not fit on pre 1953 cars even though all of the diameters are correct.
10.   Remove washer and tapered roller bearing.
11.   Remove the collapsible sleeve using a small needle nose pliers.  If the sleeve does not readily come out work the sleeve back and forth with the fingers while at the same time pulling with the needle nose pliers.  Note the bulge on the rear end of the sleeve.
12.   Using a thread file remove the stake marks from the pinion shaft.
13.    In 1939 Cadillac started to use the collapsible sleeve design.  For 1937 and 1938 cars see step 21.  The purpose was to provide the factory with a simple method to preload the pinion tapered roller bearings.  The preload in force is approximately 1200 to 1400 pounds.  This force is provided by the designed deformation of a precisely machined collapsible sleeve.  This results in the bulge noted in step 11.  The risk on disassemble is that the sleeve will now be slightly short which will excessively load the bearings before the yoke nut is tight enough.  On reassembly shims can be added to insure that this does not happen.
14.   Typically, add a .005-inch or .010-inch shim on the pinion shaft between the sleeve and the rear bearing.  This shim is 2.375” O.D. and 1.875” I.D.  It is available as a shim pack for a Dana D44 30 spline rear end.  This is available from Randy’s Ring and Pinion, 800-347-1188 as part number SK 30214.  This may also be available at other sources.
15.   Using emery cloth clean the inside of the sleeve to insure that it can be installed and removed easily.  Oil the sleeve on the ID and after adding the shims reinstall the sleeve, bearing and washer.
16.   At this time do not install the new seal but trial fit the yoke, washer and nut.  Tighten the nut snuggly and check to see that approximately 0.010 inch of endplay exists in the pinion shaft bearing assembly.  If not, disassemble and add or subtract shims.  This endplay will be removed when the nut is tightened and the sleeve collapses further.
17.   Remove the yoke one final time.  Install the new seal in the retainer and install the complete seal assemble in the differential housing.  A modern seal (National #473179, NAPA #18671, or equivalent) made with a single sealing surface is recommended over the original leather type.  Install the yoke (aligned with previous mark on pinion splines).  Before installing the yoke clean the seal surface with 400 grit wet and dry sand paper.  If seal surface is damaged in any way use a speed-i-sleeve to repair (part # 99187).
18.   Install the yoke and tighten the nut to snug and confirm again that endplay exists in the pinion shaft.  The sleeve will now need to be collapsed further to eliminate the endplay.  Tighten the nut to at least 225 ft-lbs. and measure the inch-lbs drag on the bearings.  It should be roughly the same as before disassemble but if 10 inch-lbs are achieved with used bearings and the nut is tightened to at least 225 ft-lbs the job is done.  Tool J-2659 is used to hold the yoke while torque is applied to the nut.  If tool is unavailable, something needs to be adapted.  If drag is low tighten the nut one-half flat at a time beyond 225 ft-lbs and recheck drag.  Continue until drag is correct.
19.   Stake pinion nut.
20.   Refill axle with oil and reinstall brake drums and wheels.
21.   On 1938 and small series 1937 cars a collapsible sleeve was not used.  A fixed sleeve was used with factory-installed shims to obtain the correct preload.  DO NOT ADD SHIMS TO THESE CARS.  To replace the seal on these cars no special procedures are required.  Just remove the yoke, install the seal and torque the nut.  Be sure to follow the procedures on cleaning the nut and staking procedures.
Paul Tesone
Jim - I appreciate the opportunity to view your photos and read your text . Keep them coming . Great job . Paul Tesone CLC #6876
Jim Beard
Well it has been a while since I posted any progress pics. Almost everything is in the chassis and I should be setting the body back on soon. I did the rear pinion seal just like as outlined in the above post and everything turned out great. That is my trusty brother in the background sifting though misc. nuts and bolts. How come you always have extra nuts and bolts after you put things back together?
