Oil Pump on a 38 Lasalle
Started by 1928isgreat, August 01, 2011, 06:18:33 AM
1928isgreat
Hi Guys,
A friend of mine has an Australian bodied 1938 V8 sedan. Can you confirm that there is a gasket between the oil pump and the block, as it was some time since the engine was stripped down.
Regards
Ray
Warren Rauch #4286
 Yes, there is a gasket.Group 8.3706 (1942 book)
   1410842 oil pump to crankcase gasket
   fits 36-38 all v8 and 38-40 all v-16
  Strange it fits both 8 and 16. The 39-48 v-8  engines used a different number. Warren
Brad Ipsen CLC #737
The late V-16 is essentially the same pump except the gears are slightly longer by 1/4 to 3/8 inch.  I can't remember now exactly how much longer.
Brad Ipsen
1940 Cadillac 60S
1938 Cadillac 9039
1940 Cadillac 6267
1940 LaSalle 5227
1949 Cadillac 6237X
1940 Cadillac 60S Limo
1928isgreat
