1955 Cadillac Glass Bowl Fuel Filter
Started by Kevin Kenneally, March 29, 2014, 09:14:33 PM
Kevin Kenneally
I just replaced the element in my fuel filter and had trouble with the fittings leaking until I turned the glass bowl on the bottom and it is fine.  I screwed the line out of the carb together then twisted the filter on leaving the glass bowl on the bottom.  Is there a problem with the glass bowl next to the valve cover or do I need to get it turned and have the glass bowl on the top??
txturbo
If you don't start having vapor lock issues, then leave it as is. If you do you will need to turn it with the glass bowl on top and vertical.
D. Roden
1956 Coupe De Ville PINK
1963 Cadillac Sedan De Ville
DylanFan52
I just attempted to change the filter on my 1959 Cadillac (just started restoration) and it is stuck.  It looks fragile and I certainly do not want to break the glass bowl.  Any advice?  I have soaked it in diesel fuel and applied JB Blaster to the rim but I am afraid to apply too much pressure.  Thanks!
John
Jeff Maltby 4194
I used the the rubber handle on my hammer to get the last one off tapping around it. The oem gasket is probably cork, but Napa sells a rubber gasket that might work.
Jeffo 49er chapter
CLC 1985
Honda Gold Wing GL1500
55 ledsled
Yeah they put up a fight but they will come off. That glass is pretty thick so no worries. I noticed you used rubber hoses...I fought hooking mine up bending steel lines and the guy at the Napa said why dont you just use a couple compression fittings and a piece of copper tube...easy to bend and you dont have to fight it... easiest thing I ever did! Check it out if your interested.
Mike Josephic CLC #3877
The only issue with a copper fuel is that it will cost you points on judging.
Cadillac never used a copper line.
If that's not an issue to you -- I agree bending a copper line is much easier
than trying to bend and flare steel.
1955 Cadillac Eldorado
1973 Cadillac Eldorado
1995 Cadillac Seville
2004 Escalade
2011 Buick Lucerne CX
CLCMRC Museum Benefactor #38
David King (kz78hy)
#6
Inline Tube has the parts pre bent.  FYI.
I did not see '55 listed, but '54 is, are they similar?
https://www.inlinetube.com/_p/prd14/3191014551/product/1954-cadillac-pump-to-carb-line-331-cid-cae5401
David King
CLC 22014  (life)
1958 Eldorado Brougham 615
1998 Deville d'Elegance
1955 Eldorado #277
1964 Studebaker Commander
2012 Volt
CLCMRC benefactor 197
55 cadi
I had ordered the fuel line from inline, that was suppose to be for a 1955, well it isn't exactly like it should be and hard to bend correct, still isn't on my car yet.
It was an ordeal calling them and going back and forth, they use line that is sent to them for certain cars and then they copy it, the one they have when you buy for 54/55 isn't exact, that was a year ago, maybe they have corrected.
It just didn't line up well, close, but not close enough.
Jason
1955 Cadillac sedan series 62
2005 Cadillac deville
Jeff Rosansky CLC #28373
Jason,
Any issues with the air cleaner fitting with the filter mounted there?
Jeff Rosansky
CLC #28373
1970 Coupe DeVille (Big Red)
1955 Series 62 (Baby Blue)
Dad's new 1979 Coupe DeVille
55 cadi
I didn't put the filter there, that was Adam, but yes the air cleaner does fit over the filter when filter is there, I was possibly going to mount mine there as well.
jason
Quote from: David King  (kz78hy) on September 16, 2017, 05:38:58 PM
From the parts listing, group 12.2815:
1954 to 1956: # 1461455  Carter single carb. on 1955
1954 to 1956: # 1461456  Rochester single carb on 1955
Usually, those exceptions are well understandable, but here I'm a little bit lost...One thing is sure: there is a different fuel line if the carb is a Rochester or a Carter.
55 cadi
Yes there is a difference, I ordered the carter because I have the carter
Maybe they sent wrong one? I don't know, there is no number or anything on the tube that states which its for
Jason
J. Gomez
I had to made my own for my ’56 Rochester my first try one of the flares was not on good shape so I had to re-do it again.
The “S” bends are a pain  >:( but if you work very slow and keep moving the tube bender slightly forward from the start (about 1/8” or so) of the bend while applying some heat (I’ve use a heat gun higher setting) around it makes it easier to make the bends.
Heat is also the key in making the double flares as well as turning the compression tool is small increments.
You can use the copper/nickel alloy tubing which is much easier to bend than the steel or maybe aluminum. The only problem with these is there could be point reduction if your car is judged.
Good luck..!
J. Gomez
CLC #23082
novis
About the vapor lock.
I had many probleme with vapor lock efter they changed the petrol here in Sweden. When I drow at way no probleme but in town the car stopped when I stand at red light. I tried many things, new pump, put in an electric pump, isolated the fuel tube etc, now worked. I met an old man an he said you must put in a back tube to the tank so the petrol can circulate.  He told me to drill a 0,6 mm hole at the tube between pump and carburator and then mont a rubber tube back to tank. I did that and after that no more probleme. I can cruise at very low speed and never vapor lock anymore.
i put in a fuelfilter before the pump and took away the glassfilter.
See picture.
Karl.H
