Author Topic: Project - 1968 DeVille Convertible  (Read 9243 times)
Offline dwbic
      CLC Member #29861
  • Name: Don Bickel
Re: Project - 1968 DeVille Convertible
« Reply #40 on: January 28, 2015, 10:22:09 AM »
We completed the replacement of the door skins on both sides of the car - short video slideshow here:  http://youtu.be/25rOUqFMhOE
Now on to the front fenders - which should be the last component of the metal/rust repair!  Both fenders are rusted away behind the wheel well, including the inner support braces being rusted away, so we'll have to re-create those as well as putting in the purchased patch panel for the outer skin.
Rebuilt the QuadraJet carburetor so it is ready to go.
Don
Don
Offline JoeKarasinski
  • Name: Joe Karasinski
« Reply #41 on: January 28, 2015, 11:23:56 AM »
Nice work!
Offline DeVille68
      CLC Member #30616
  • Name: Nicolas Hubacher
« Reply #42 on: January 28, 2015, 03:06:04 PM »
nice!  8)
Looks like a lot of work!
Offline cadman56
      CLC Member #5820
  • Name: Larry Blanchard
« Reply #43 on: February 10, 2015, 03:28:44 PM »
I have two 68 convertibles & a very nice coupe for parts.  I was going to do a frame-off on one of the convertibles, but after completing a frame-off of a 67 Eldorado (shown at Lancaster, PA GN), two frame-on restorations of 56 coupes, a frame-off of a 56 series 62 convertible, and a frame-off of a 47 Plymouth P-15, a body-on of my 91 Fleetwood Brougham, I think I should quit.  Good luck on your project.  Larry
1956 Cadillac Eldorado Seville
1967 Cadillac Eldorado (sold)
1968 Cadillac Convertible
Larry Blanchard CLC #5820
Offline dwbic
      CLC Member #29861
  • Name: Don Bickel
« Reply #44 on: May 23, 2015, 04:34:33 AM »
It's been a lot of body work over the last couple months, but things are starting to come together now.  The frame and suspension are at powder coat and should be done next week. Once we put the suspension on we will mount the body for final fit and prep for paint.  The engine came back from the machine shop and the major engine assembly is done.  Attached are before and after photos of the engine.
Don
Don
Offline DeVille68
      CLC Member #30616
« Reply #45 on: May 23, 2015, 02:12:45 PM »
nice!
Quite a difference!
What ignition system will you run? Original or HEI?
Offline dwbic
      CLC Member #29861
  • Name: Don Bickel
« Reply #46 on: May 23, 2015, 07:31:32 PM »
Hi Nicolas,
I am planning to just run the original ignition system.
Don
Offline dwbic
      CLC Member #29861
  • Name: Don Bickel
« Reply #47 on: June 07, 2015, 07:11:11 AM »
This week I got the frame and most of the suspension parts back from sandblast and powder coat.  Started to mount the front suspension to the frame - still need to finish sandblasting, painting control arms and replace the ball joints in the next week.  Also painted the firewall and started undercoating the body.
Don
Offline DeVille68
      CLC Member #30616
« Reply #48 on: June 07, 2015, 03:05:47 PM »
nice!
Have you measured the frame?
Best regards,
Nicoals
Offline dwbic
      CLC Member #29861
  • Name: Don Bickel
« Reply #49 on: June 07, 2015, 06:11:30 PM »
Yes, I have measured the frame - it is in great shape (unlike most of the body), square and level!
Don
Offline dwbic
      CLC Member #29861
  • Name: Don Bickel
« Reply #50 on: July 04, 2015, 06:24:43 AM »
Finished rebuilding the front and rear suspension control arms with new ball joints and bushings.  Mounted the suspension and steering to get to a rolling chassis.  Re-installed the fuel lines.
Then dropped in the engine, transmission and driveshaft.  Now it is starting to look like something again!
Don
Offline Ralph Messina CLC 4937
      CLC Member #4937
« Reply #51 on: July 04, 2015, 09:59:19 AM »
Great job. The hidden skeleton of a Cadillac is often more impressive than the outside.
Ralph
1966 Eldorado  http://bit.ly/1OrxLoY
2010 GMC Yukon
Offline savemy67
      CLC Member #29202
  • Name: Christopher Winter
« Reply #52 on: July 04, 2015, 10:02:56 AM »
Hello Don,
Your work looks terrific.  I viewed your slide shows on the rear quarter and door skin repair, and I am looking forward to your slide show on the fenders.  In one of the photos in your most recent post I noticed you have a Miller welder.  Which model is it?  What wire size and settings did you use for the panel replacements?  Keep up the good work.
Christopher Winter
Christopher Winter
1967 Sedan DeVille hardtop
Offline Bill Young
  • Nothin's Lackin When Your Cadillac'n
      CLC Member #17476
  • Name: William W. Young
« Reply #53 on: July 04, 2015, 10:06:56 PM »
Beautiful work. I see You are from Peru Illinois. My Father graduated from LaSalle Peru Township high School in 1936. My Grandfather John Young was the head of the Lehigh Portland Cement Co. Plant in Peru. As a matter of fact Grandad's name is on the School's brass plack as head of the School Board when it was built in I think 1928.
1972 Cadillac Fleetwood Eldorado Convertible in Coronation Red , White top , White seats with Oxblood dash and carpet
Offline dwbic
      CLC Member #29861
  • Name: Don Bickel
« Reply #54 on: July 05, 2015, 08:57:04 AM »
My son is a senior this year at La Salle Peru Township High School.  I'll have to look for your grandfather's name on the brass plaque.
Don
Offline dwbic
      CLC Member #29861
  • Name: Don Bickel
« Reply #55 on: July 05, 2015, 08:59:48 AM »
I'll check that information and let you know.
Don
Offline dwbic
      CLC Member #29861
  • Name: Don Bickel
« Reply #56 on: July 10, 2015, 02:28:48 AM »
Christopher,
Here is a photo with the model & settings, using 0.023" wire.
Don
Offline savemy67
      CLC Member #29202
« Reply #57 on: July 10, 2015, 03:08:10 PM »
Don,
Thanks for the info.  I have a Hobart Handler 140 (Hobart is made by Miller).  Did you experiment with wire size and settings or did you know at the start that 023 wire and relatively hot and fast machine settings would work?  Any issues with heat distortion?  I have to do some welding on both my front fenders so I appreciate finding information from '67 and '68 owners.  Thanks.
Christopher Winter
Christopher Winter
Offline DeVille68
      CLC Member #30616
« Reply #58 on: July 25, 2015, 01:50:32 PM »
Hi Don!
Very nice work!
Could you send me a link to your album? So I can download you pictures of the frame for my reference.
Best regards,
Nicolas
Offline dwbic
      CLC Member #29861
  • Name: Don Bickel
« Reply #59 on: August 02, 2015, 07:43:08 AM »
Don
