Author Topic: Something has changed around here?  (Read 1888 times)
Offline D.Yaros
  • The Gray Lady, a '55 Coupe de Ville
  • Ed./Pub. Car Collector Chronicles
  • Name: Dave Yaros
« on: August 21, 2014, 11:47:35 AM »
The link I have been using forever to get to the forum stopped working as of yesterday (20 Aug 2014).  Why?
When I use the link I have been using for years - http://www.cadillaclasalleclub.org/forum/ - I get this error report
Not Found
It looks like nothing was found at this location. Maybe try a search?
I have found a new link which appears to work - http://forums.cadillaclasalleclub.org/ -
Just wondering ... ?
Dave Yaros
CLC #25195
55 Coupe de Ville
92 Allante
62 Olds
http://GrayLady.atwebpages.com -'55 CDV site
Offline The Tassie Devil(le)
  • Administrator
      CLC Member #18992
  • Name: Bruce Reynolds
Re: Something has changed around here?
« Reply #1 on: August 21, 2014, 07:35:16 PM »
I am with you.   I found the link I was using was doing the same, and I simply updated my link.
I thought it was my computer that was acting up.
'55 Buick Special Post Coupe (LHD)
'74 Chris Craft Gull Wing RHH
Offline J. Gomez
      CLC Member #23082
  • Name: J. Gomez
« Reply #2 on: August 21, 2014, 07:56:13 PM »
Dave, Bruce,
The site was updated last Saturday per this message-> http://www.cadillaclasalleclub.org/category/clc-news/.
I've also had the same problem over the weekend and had to dig around the main CLC site to read the news. Too bad there was not a broadcast message place on the forum to alert others of the upcoming changes.  :(
J. Gomez
CLC #23082
Time is irrelevant when you work on your classic car, eventually you will enjoy it..!
  • Administrator
      CLC Member #18992
« Reply #3 on: August 21, 2014, 09:42:08 PM »
Probably done to keep ouy brains active?
Offline D.Yaros
  • Name: Dave Yaros
« Reply #4 on: August 22, 2014, 10:22:25 AM »
Ah ha!  So, it was not just me?  Good to know.
Reminds me of the childhood taunt about going home only to find out that your parents had moved ... .
« Last Edit: August 22, 2014, 10:26:56 AM by D.Yaros »
Dave Yaros
CLC #25195
55 Coupe de Ville
92 Allante
62 Olds
Offline gross707
      CLC Member #22185
  • Name: Gerald Ross
« Reply #5 on: September 22, 2015, 06:30:50 AM »
So how does one find all the forums, i.e. Restoration, technical, etc?
Gerald
Gerald Ross
  • Administrator
      CLC Member #18992
« Reply #6 on: September 22, 2015, 07:27:05 AM »
Not sure what is going on here if you can't see them, but they are there.
If you can see the Forum Support Forum, which you are posting on now, you should be on the same page as the rest of them.
Offline gross707
      CLC Member #22185
  • Name: Gerald Ross
« Reply #7 on: September 23, 2015, 06:36:30 AM »
My old routine was to click on "Forum Home" and I would get to a screen that offered Authenticity, Techncal, Restoration and For Sale.  Now when I click on that same button I get only "for sale" blogs.
I read the other posts in this tread and went to the new webpage linked with one of the above posts but could not discern a way out of this dilemma.
Gerald
Gerald Ross
Offline gross707
      CLC Member #22185
  • Name: Gerald Ross
« Reply #8 on: September 24, 2015, 05:47:10 AM »
I found it.  All is right in my world again!
GR
Gerald Ross
  • Administrator
      CLC Member #18992
« Reply #9 on: September 24, 2015, 07:02:42 AM »
Good O.   What was it?
Offline gross707
      CLC Member #22185
  • Name: Gerald Ross
« Reply #10 on: September 25, 2015, 05:46:18 AM »
Not sure.  I had to click an arrow somewhere near the top right and then all the headings appeared. Obviously I'm no computer expert.
GR
Gerald Ross
Offline David Greenburg
  • CLC #3830
      CLC Member #3830
  • Name: David Greenburg
« Reply #11 on: September 25, 2015, 10:48:34 AM »
I just link to "unread messages" and see everything new in all categories.
David Greenburg
'60 Eldorado Seville
'61 Fleetwood Sixty Special
  • Administrator
      CLC Member #18992
« Reply #12 on: September 25, 2015, 06:54:48 PM »
GR
All of us were computer novices at one time, and I am definitely no expert yet.
I should learn to type with more than one finger before I wear that one out.
