1961 Eldorado - coming together
Started by P. Manoogian, April 03, 2016, 08:36:43 AM
P. Manoogian
Long time coming...
1962 Corvette 327 - 250 HP Automatic Triple Black
1963 Impala SS Convertible - 283 Automatic Black Red Gut White Top
1965 Impala SS Coupe  - 502 Turbo 400 - Crocus Yellow
1974 Corvette L84 4spd Coupe - White / Black Leather
P. Manoogian
Ask me how I made replacement clips for ten front fender moldings.
P. Manoogian
Dive into the hood...hard color to lay out...used "flop" to stabilize metalflake. Color has 2 types of metalflake.
Smedly
Lookin good. keep the photos coming
Sheldon Hay
P. Manoogian
59-in-pieces
Peter,
Although I don't have this car - I'll bite.
How did you make the clips.
Your method may tweak someone's imagination to make some for themselves.
Have fun,
Steve B.
S. Butcher
P. Manoogian
Use #6 stainless 3/4" pan head screws. File or grind the head and put two fine grooves on opposite edge near head so they slide in the molding track. If you remove the right amount of material, and not too much, they will slide and be snug so when you put the nut on from the backside they will not spin.
