68 Deville
Started by gwmcd, May 18, 2016, 11:41:40 AM
gwmcd
Where is the horn relay located?
Vinny6t6
I believe it is located on the passenger side of the engine compartment attached to behind the radiator core support.
1966 DeVille Convertible
1980 Eldorado Biarritz
1993 40th Anniversary Corvette 6 Speed
Julien Abrahams
If it is at the same location as a '67, then Vinny is correct.
1954 Cadillac series 62
1969 Austin Healey Sprite
1979 Opel Kadett
Kell Oskarsson
According to the ´68 Shop Manual, the horn relay is located inside the car to the upper left of the brake pedal.
Kell Oskarsson
1968 Sedan de Ville
1979 Chevrolet Caprice Classic Sedan
