My 1961 Cadillac Tranny is leaking from O ring at gear select
Started by Jack Miller CLC# 24441, June 21, 2016, 10:28:04 PM
My 1961 Cadillac transmission is leaking from (I Think) the O ring that goes around the gear select on the tranny body. I never worked on a transmission. It only leaks when sitting, not driving.
Has anyone here had this issue and can tell me what to do ?
Besides that the tranny shifts great.
Jack
1961 Cadillac
russ austin
The shifter shaft and TV linkage need to be removed and have new O rings installed.  Call around to see who works on Hydra-Matics. Its not surgery, but a few precise measurements need to be made.
R.Austin
P. Manoogian
i did it on mine. get a service manual as it explains how. you can do it without removing transmission. You need to drop pan, disconnect linkage, etc. 90% common sense job. Get an o ring kit at parts store and you will find what you need.
1962 Corvette 327 - 250 HP Automatic Triple Black
1963 Impala SS Convertible - 283 Automatic Black Red Gut White Top
1965 Impala SS Coupe  - 502 Turbo 400 - Crocus Yellow
1974 Corvette L84 4spd Coupe - White / Black Leather
goofyhb
Hello,
I have the same problem over here in Germany. Can anyone give the exact measures of the O-rings needed? Thickness and Diameter. I'll have to order them upfront.
Thanks in advance,
Axel
1955 Series 62 Sedan http://bit.ly/1Ri914p
1949 Buick 56S
1960 Series 62 Convertible
1960 Fleetwood
I ended up bringing it into a tranny shopmthat specializes in classic cars. My split converter was leaking, the reverse gear was stripped and the band's inside tranny were hard as a rock. Got everything replaced. Guy said it will bang a little from R to D till it sets.
Tranny great now with no mire leaks.
Jack
1961 Series 62 convertible
Quote from: goofyhb on May 14, 2017, 01:57:13 PM
Hello,
Axel
Axel, you can order just that kit here: http://www.autotran.us/ It comes with 2 O-rings, a washer and the small pin.
Check the removed shaft for rust.  The problem here has been the shaft rusts
from the outside, then the rust destroys the seal.  good luck, Bruce Roe
goofyhb
Changed the seals last weekend. Also the O-ring on the tube to the pump. All were rock solid. I disassembled all valve bodies and cleaned everything. Still have a slow shift between 1 and 2 and a hard shift between 2 and 3. I had a whine from the rear planetary gears, but this is now reduced after a 60 mile trip on the Autobahn at 60mph. I probably have to work on the adjustment of the TV rod to get all the shifting becoming smooth like the 3 to 4 shift. I need to install a rev counter to better tackle this task.
1949 Buick 56S
1960 Fleetwood
