1969/1970 Clock
Started by Dan LeBlanc, May 11, 2017, 08:38:08 PM
Dan LeBlanc
Looking for a 1969 or 1970 clock. Running preferred or non working in need of a good clean and lube with good coils are ideal.
Was outbid on two clocks on ebay in 2 weeks by the same bidder who now has them for sale in their ebay store for $400 (4 times what the winning bid was).  I won't mention the seller but if you search for 1970 parts, and find overpriced junk that's the guy. He has 2 ebay id's.
Dan LeBlanc
chrisntam
I know the seller you speak of. You are spot on with your assessment.  You want a gasket for a door handle?  That'll be $275 + $50 shipping.
On your clock, why not take yours out and have it converted to quartz movement?  Some don't like the quartz movement due the second hand sweeping smoothly, not one second at a time.  Not an issue for me,  had mine converted.
Why not send yours out for either repair or conversion?  I bought one on ebay a year or two ago, had it converted to quartz, the only downside is the wood grain color did not match exactly.  I do suggest you have your existing clock restored/converted due to the wood color matching issue.  If I recall correctly, the wood grain portion may be able to be moved from one clock to another, not 100% sure though.
I'll look to see what I have, I may have two, I'll let you know.
chris.
1970 Deville Convertible
Dallas, Texas
Jeff Rosansky CLC #28373
I converted mine to quartz. You can take the woodgrain off of yours and transplant it to another.
Jeff Rosansky
CLC #28373
1970 Coupe DeVille (Big Red)
1955 Series 62 (Baby Blue)
Dad's new 1979 Coupe DeVille
Dan LeBlanc
I prefer to have mine ticking - it adds to the cool factor for me
Yup. Sounds like you found the same seller. Old untested brake booster and master cylinder, that'll be $300. Bloody heck, I can go down and get rebuilt stuff at O'Reilly with a warranty for $185 total.
Dan LeBlanc
chrisntam
#4
This is what I have, the case is rusty and the knob is stuck on the shaft.  I think it came from a junker in the northeast.  I'd like to keep the exterior woodgrain, it matches the bezel I put in the car, but the knob appears to be stuck pretty good.  I would assume it is not working.
Pics below:
Dallas, Texas
To remove the knob, you have to hold the shaft very tightly and unscrew the knob.
It will come off.
chrisntam
Thank you for the advice, I figured it was a press fit.  I'll give it a spin and try that.
Thanks again!
chris.
Dallas, Texas
Dan LeBlanc
When you get it opened up, let me know if the two coils look burned, or if there are any broken wires to and from them.
Dan LeBlanc
chrisntam
Yeah!  We have both!  Burned coils and loose wires!
Thanks to Bruce & Dan for the tutorial on how to "unscrew" the knob and how to identify toast inside a clock!
chris.
Dallas, Texas
Dan LeBlanc
It's only slightly crispy on the inside!
Dan LeBlanc
chrisntam
Dallas, Texas
Dan LeBlanc
Snapped it up and should have it for the weekend.  I'll still clean and lube the internals, and add an inline fuse as well.
Dan LeBlanc
