1958 Cadillac series 62 heater hose fittings
Started by john estes, May 21, 2017, 07:40:49 PM
john estes
In need of the two fittings that thread into the water pump where the heater hoses attach. Thanks
John Estes
One is a short stubby straight one and the other is longer and curved.   Mine were ok, but I saw them somewhere a few years ago, check with the Cad water pump repair guys.   They might have been with a repro pump or something.
You might have to improvise with some new pipe spools.   You can weld a bead on the end for the hose rib.   I can take pictures, if you need.
