Author Topic: 68 SDV tele/tilt woes  (Read 371 times)
Offline taintedsaint
  • Name: Joe Slater
« on: May 24, 2017, 05:49:12 PM »
Not new info for you experts, the dreaded 'broken signal lock cam' issue on my tele/tilt. Won't lock in right turn position, state inspector says it has to. Of course, searching for a replacement has yielded $200 > prices for replacement which could break first time it gets used. So question for the experts, can I swap in a no-tilt column? Any other large body GMs with tele/tilt I could hunt down for repair pieces? Car is an original 18K mile survivor and it pains me to remove pieces but my back is against the wall on this one.
I truly appreciate ANY type of input.
Offline Dave Shepherd
Re: 68 SDV tele/tilt woes
« Reply #1 on: May 24, 2017, 06:00:21 PM »
Pretty sure a same year column will work, but could be hard to find. Maybe someone has an old Hollander exchange book that would have the crossover info.
Offline chrisntam
  • Dallas, Texas
      CLC Member #29206
  • Name: C. Jessen
« Reply #2 on: May 24, 2017, 06:34:54 PM »
So a turn signal switch for a '68 with tilt & tele is not readily available?
Seems like a column would be more expensive than a replacement switch.
1970 Deville Convertible  MTS 507
Dallas, Texas
« Reply #3 on: May 24, 2017, 07:54:02 PM »
Well that would make sense, gotta do your due diligence and hit the internet to find that switch, Caddydaddy, Usa auto parts, just keeping searching.
Offline bcroe
      CLC Member #14630
« Reply #4 on: May 24, 2017, 08:42:51 PM »
Quote from: taintedsaint
Huh, I thought tilt columns used the same turn signal switch as non tilt.  What
might vary is the turning light function not on most cars.  Probably a simple
switch without this would get you function without luxury.
My experience is that all high end cars have tilt; the telescope is optional.  I
use neither and have installed fixed columns in all except the Eldo, can't find
one.  The telescope columns are far harder to work on, for me.  Bruce Roe
Offline Scot Minesinger
      CLC Member #20543
« Reply #5 on: May 24, 2017, 09:31:11 PM »
Call Cadillac King in CA they should have the column part you need.  A tilt/tele. column makes the car more valuable.  Any 1965 and newer Cadillac without tilt/tele. column, trunk release, and twilight sentinel I add in.  Got to have those options.  Changing out a column is more difficult - think about refinishing to match - those are all color matched - not all black like a 69/70.
Offline bcroe
      CLC Member #14630
« Reply #6 on: May 24, 2017, 09:51:35 PM »
I think he just needs the switch.  But installing it is a lot more difficult in
a telescoping column.  Swapping columns isn't hard between the same
type car, but getting the color and wheel to match is another thing.  For
several good reasons, my 79 Eldo has a 79 Riv column that was removed
from a 79 Toro; doesn't match, but it works.
My guess is that the turn switch from any 79-85 Eldo/Riv/Toro would solve
the problem, including turn lights.  Bruce Roe
Offline D.Smith
  • 1961 Sedan deVille
      CLC Member #17592
  • Name: Dave Smith
« Reply #7 on: May 24, 2017, 10:45:06 PM »
The 68 turn signal switch with T&T is different than the non-T&T switch.
Replacements are long gone.   This is a common failure on 68s with T&T.
Offline bcroe
      CLC Member #14630
« Reply #8 on: May 24, 2017, 10:57:14 PM »
Sorry to hear, my guess is just wrong; no later equipment can be adapted.
Bruce Roe
Offline D.Smith
      CLC Member #17592
  • Name: Dave Smith
« Reply #9 on: May 25, 2017, 05:21:05 AM »
Some detailed info here from another club member.
http://www.eldorado-seville.com/files/turnsignalswitch.php
Offline cadillactim
  • Cadillac Tim
« Reply #10 on: May 25, 2017, 06:20:24 AM »
The non tilt switch is completely different. Only 67-68 will work (T-T). Often you can replace the cam. I've rebuilt many of these switches. In some cases the plastic on the switch housing was worn too bad to be rebuilt. But since yours is a low mileage car yours is probably okay as long as there was no arcing causing part of the plastic to melt.
You can install a non tilt column, but they have the same cam breaking issue, just a bad design for those two years. However you can get replacement non tilt switches.
Tim
Tim Groves
Offline D.Smith
      CLC Member #17592
  • Name: Dave Smith
« Reply #11 on: May 25, 2017, 06:41:22 AM »
Tim
Caddy Daddy has reproduction non-tilt switches.     Which is odd as you'd think more cars were ordered with T&T.    I would have reproduced those first.
« Last Edit: May 25, 2017, 06:43:22 AM by D.Smith »
Offline klinebau
  • Name: Kurt Linebaugh
« Reply #12 on: May 25, 2017, 08:36:15 AM »
Is the switch the same as the '70?  The tilt/tele turn signal switch is available for the '70 at Rockauto.
1970 Cadillac Deville Convertible
Detroit, MI
Offline D.Smith
      CLC Member #17592
  • Name: Dave Smith
« Reply #13 on: May 25, 2017, 09:11:46 AM »
Nope.   Fits two years only.
Offline m-mman
      CLC Member #29634
  • Name: J. Crabtree
« Reply #14 on: May 25, 2017, 01:05:39 PM »
For what it is worth Saginaw sold the T&T columns to Chrysler during those same years and Imperial owners suffer the same problems. (issues discussed regularly at http://www.imperialclub.com/ )
As I remember the basic problem stems from having the switch is located not behind the steering wheel but further down the column(?)
Early experimentation with T&T columns resulted in a bad design.
How often are you inspected? Perhaps you could temporarily install a fixed column that works. (it shouldn't cost much and the color wouldn't mater) and then swap back to the T&T later?
1929 341B Town Sedan
1971 Miller-Meteor Lifeliner ambulance
Other non-Cadillac cars
Near Los Angeles, California
CLC #29634
  • Name: Joe Slater
« Reply #15 on: June 13, 2017, 01:03:33 PM »
I appreciate ALL the replies to my post. I have tried CaddyDaddy, Cadillac King, and lists of others. Talked to every hot rod column maker (ididit etc.) and several builders (Dave Kindig). They are all aware of the unique cam which has barbs on it that hold the signal in place until wheel returns to neutral position and the cam is WAY different than non-tilt. ANd yes, it is a bit farther down column as well. We have annual inspections so swapping back and forth would get to be a pain. I'm hoping inspection tech may let it slide. Short of any other fix, I plan to pull column and swap in either a non-tilt or an aftermarket so the car is driveable and then dive-in to the possibility of having the cam 3D scanned, modeled and perhaps manufactured. I found ONE of these cams on Ebay last week for many hundred dollars and again, it could fail first time out. I do appreciate everyone's input immensely. Interchange manuals show it only swaps with 67 SDV but I have to believe there is antoher GM vehicle with the same cam even if the entire column isn't the same. The hunt will continue as I am now on a mission from the Caddy gods. ;D
Offline bcroe
      CLC Member #14630
« Reply #16 on: June 13, 2017, 01:39:27 PM »
Making a new part is always a possibility, if someone can and will take all the
trouble to do it.  You might find quite a demand for it.  good luck, Bruce Roe
Offline David King (kz78hy)
  • Check out the Eldorado Brougham Chapter
      CLC Member #22014
  • Name: David King
« Reply #17 on: June 13, 2017, 05:59:39 PM »
David King
CLC 22014  (life)
1958 Eldorado Brougham 615
1959 Eldorado Brougham 56
1960 Eldorado Brougham 83
1998 Deville d'Elegance
2003 Deville gifted to daughter
1964 Studebaker Commander
1966 Pontiac GTO convertible
2012 Volt
CLCMRC benefactor 197
Director and Founder, Eldorado Brougham Chapter of the CLC
Past President, Motor City Region of the CLC
Rare Parts brand suspension parts Retailer
Offline cadillactim
  • Cadillac Tim
« Reply #18 on: June 13, 2017, 08:12:31 PM »
You can get replacement cams. You want the RED cam, the white ones aren't good quality. I believe the company is     S & M who makes them. You want the SM-15 cam. There might be one on ebay.
Tim
Tim Groves
