Author Topic: Museum Project 1942 Cadillac Series 75  (Read 550 times)
Offline Barry M Wheeler #2189
  • Administrator
      CLC Member #2189
  • Name: Barry Wheeler
« on: May 26, 2017, 10:26:04 AM »
We have another "need" for the 1942 Cadillac that was donated to the CLCMRC museum in Hickory Corners, MI. Sometime in the past, probably when a previous owner wanted new whitewalls and found that 7:50 X 16" WW were no longer available (at that time), he went to a junkyard and got a set of 15" wheels.
So, now we need a set of 16" wheels that can be from: 1941-48 Series 67/75. Prefer within driving distance from Chicago, Indianapolis, or Detroit. '
As I mentioned in my other ad, donations are gratefully appreciated, or we do have a small budget for parts. We prefer to pick them up but we could possibly tag them and send by bus. Donations are tax deductible.
We also still need a RH NOS/reproduction 1941 tail lamp jewel. (We may be able to make a LH one work if that's all you have.) See note of clarification below. (They are both the same.) Thanks to Bob Hoffmann for catching my error about usage. I thought that this was going to be too easy...
« Last Edit: May 26, 2017, 06:26:49 PM by Barry M Wheeler #2189 »
Barry M. Wheeler #2189
1981 Cadillac Seville
1979 Cadillac Fleetwood Brougham
2016 Cadillac ATS
Offline Steve Passmore
  • Name: Steve Passmore
Re: Museum Project 1942 Cadillac Series 75
« Reply #1 on: May 26, 2017, 12:07:08 PM »
Barry, there's no right or left tail light jewel in 41. They are both the same.
Offline Bob Hoffmann CLC#96
      CLC Member #96
« Reply #2 on: May 26, 2017, 05:05:16 PM »
Barry,
 I suggest you reread the MPL on the wheel interchange. Hint... the big series wheels are wider.
 HTH, Bob
1941 62 coupe custom maroon
1970 DeVille conv. triple black
  • Administrator
      CLC Member #2189
« Reply #3 on: May 26, 2017, 06:22:20 PM »
Steve, Since Glenn Brown donated a NOS complete LH tail fin assembly, I have been ragging the membership in asking for a "RH" jewel. (And trusting that they will know that there is no difference between the two.) Sorry if I confused you.
2016 Cadillac ATS
  • Administrator
      CLC Member #2189
« Reply #4 on: May 27, 2017, 03:11:48 PM »
Yes, I saw the ad in the S/S and called right away.
2016 Cadillac ATS
Offline gary griffin
  • garygriffin@Q.com
  • Name: Gary Griffin
« Reply #5 on: May 27, 2017, 07:59:05 PM »
  In the 70's  3/4 ton  pick ups went to 16.5 inch wheels and tires and 16 inch tires were hard to find so many went to 15  inch wheels from the local junk yard.   My 1942   6719 had 15.s on it when I purchased it and I found correct wheels from several places one or two at a time.  I eventually had the 5   16's that I needed.
Gary Griffin
1942 Cadillac 6719 (parts car) (Gone)
Offline Scott Anderson CLC#26068
  • Registered User
  • 1941 Series 62 CCP (6267D) CLC, AACA, CCCA
      CLC Member #26068
  • Name: Scott Anderson
« Reply #6 on: June 04, 2017, 02:37:30 PM »
Hi Barry - (Don't know if you recall me by name, I was a moderator for awhile a few years ago). In any case,I have a set of 15" wheel covers if those are of interest.
Email me at sanderson1962@gmail.com.
Scott
Offline Tim Pawl CLC#4383
      CLC Member #4383
« Reply #7 on: June 09, 2017, 12:00:57 PM »
Barry,
CLCMRC recently received donation of two of the 16 inch wheels with the six bolt pattern...Is that what you are looking for?
Tim Pawl CLC#4383
  • Administrator
      CLC Member #2189
« Reply #8 on: June 11, 2017, 07:56:11 PM »
Tim, thanks for checking, but the six bolts are for 1938-40 Series 75/90 I believe. We did purchase the set of wheels in the S/S this month and Glenn Brown should be picking them up soon. We are checking as the restorer believes that he remembers that the build sheet specified black wall tires. Does anyone have a set of 7:50 x 16" blackwalls that they don't need?
2016 Cadillac ATS
Offline Tom Boehm
      CLC Member #6750
  • Name: Tom Boehm CLC #6750
« Reply #9 on: June 19, 2017, 03:46:07 PM »
Hello Barry, I have two. Will this car be driven or displayed? They are BF Goodrich Extra Miler. They are well over twenty years old.  Tom Boehm New Albany, IN
