Author Topic: removing inside door handle and cozy wing crank. 1955  (Read 266 times)
Offline GasWorksGarage
  • Name: GasWorksGarage
« on: June 09, 2017, 01:27:57 PM »
What holds the inside handles on?
Thanks in advance C. Sams
Offline D.Yaros
  • The Gray Lady, a '55 Coupe de Ville
  • Ed./Pub. Car Collector Chronicles
  • Name: Dave Yaros
Re: removing inside door handle and cozy wing crank. 1955
« Reply #1 on: June 09, 2017, 02:11:08 PM »
Cannot speak specifically to Caddy,  but most GM cars of that year used a spring clip to hold the handle onto the shaft.  Removal requires the use of a commonly available door handle removal tool -
https://www.amazon.com/Dorman-76951-Window-Handle-Removal/dp/B000CO96VI
Dave Yaros
CLC #25195
55 Coupe de Ville
92 Allante
62 Olds
http://GrayLady.atwebpages.com -'55 CDV site
Offline David Greenburg
  • CLC #3830
      CLC Member #3830
  • Name: David Greenburg
« Reply #2 on: June 09, 2017, 04:58:36 PM »
I've never heard the term "cozy wing" before. Sorry I can't help with your question, as my cars have electric cozy wings.
David Greenburg
'60 Eldorado Seville
'61 Fleetwood Sixty Special
Offline MickeyCaddy
      CLC Member #29849
  • Name: M Chanslor
« Reply #3 on: June 10, 2017, 01:06:21 AM »
Each door handle and window crank has a spring-loaded collar that has to be pressed firmly toward the inside of the door to reveal the standard 1955 GM spring clip. They can be very frustrating to work with.
Buy some extra clips before you start. There are 2 sizes of clips; they look similar, but the slightly smaller ones fit perfectly. The larger ones will work, but they prevent the spring-loaded collar from seating properly. I bought both sizes at Auto Zone.
I tried several of the clip removal/installation tools available online, but had better luck with a couple of sharp picks, one straight and one with a quarter-inch 90-degree bend at the tip.
Good luck!
Michael Chanslor
Offline chrisntam
  • Dallas, Texas
      CLC Member #29206
  • Name: C. Jessen
« Reply #4 on: June 10, 2017, 05:05:51 AM »
The little clip fits in the slot, you have to push the clip out, which will allow the handle to come off the stub sticking out of the door panel.
https://www.youtube.com/watch?v=0Ym4dhm60Og
« Last Edit: June 10, 2017, 05:23:07 AM by chrisntam »
1970 Deville Convertible  MTS 507
Dallas, Texas
« Reply #5 on: June 14, 2017, 09:22:59 AM »
Thanks all. I got it.
