Author Topic: 1957 Eldorado paint  (Read 342 times)
Offline vegas49er
      CLC Member #25203
  • Name: f. johnson
1957 Eldorado paint
« on: June 09, 2017, 06:14:51 PM »
Hi, I have a 57 Eldorado with code 98 paint. Copper metallic. I am not finding anyone with the paint mix for that color in Las Vegas area. I do have the Ditzler PPG and Dupont numbers but the are dis-continued and/or can't be crossed. I am having a paint match done now from some interior pieces but hard to match as it was lacquer. Anyone that may have a mix code with a brand name would be appreciated.
You could also e-mail me at fjoh432@gmail.com. Thanks. F. J.
Offline Seville1957
  • Name: Willie Outlaw
Re: 1957 Eldorado paint
« Reply #1 on: June 09, 2017, 09:47:15 PM »
I feel your pain, I'm still searching for an Olympic White code 90 paint for my 57 Seville. There have been several sites I've run across but haven't executed yet. Below is one of the sites that claims to have our paints and even in lacquer but it's not cheap!
http://www.autocolorlibrary.com/aclchip.aspx?image=1957-Cadillac-pg01.jpg
Offline vegas49er
      CLC Member #25203
  • Name: f. johnson
« Reply #2 on: June 10, 2017, 10:41:26 AM »
I've heard of them. I am having a shop try to paint match so will see them on Monday and hope for the best. Thanks.
Offline collector
  • Name: john rutenberg
« Reply #3 on: June 10, 2017, 05:34:33 PM »
There is a company that has PPG Acrylic lacquer, (which as you know that is what your car was originally painted with). They have the old books and can formulate the colors for you. Its Scottsdale Paints in AZ.
 Auto Color Library doesn't use PPG any longer and they try and get you to use their own paint. They try and match the colors to chips but it is never the same. They actually don't have formulas for their own lacquers. I stopped using them once they stopped using PPG. I needed the exact formula not a close proximity.
Offline P. Manoogian
  • CLC #29766
  • Name: P.Manoogian
« Reply #4 on: June 10, 2017, 06:07:04 PM »
Try a brand called BASF Limco. That is the only brand I could find that had a formula for my 61 Code 99 Shell Pearl Biarritz.
1959 Coupe DeVille - Vegas Turquoise
2012 CTS Coupe- Crystal Red
1970 AMX
Offline vegas49er
      CLC Member #25203
  • Name: f. johnson
« Reply #5 on: June 11, 2017, 09:48:14 AM »
Thanks for the information all. I will research it. F.J.
Offline fishnjim
      CLC Member #29423
  • Name: J. Bozin
« Reply #6 on: June 12, 2017, 12:13:53 PM »
If you have the code or formula, then get in contact with someone that has an PPG refinish account* and they should be able to get on the computer system and cross/match.   They don't let just anybody on that system.   I tried.    * - or a salesman that goes around to the parts stores.
Axalta is the former DuPont now.   You can try them also.
TCP global used to let you on, but they got selfish.
Some of the components may not be available and what you're finding, but they should be able to tell one way or the other and what matches.   So spotting maybe out of the question - ie, repaint necessary.   You can always shoot it in acrylic enamel and it'll look period/one part.   If you're going over, (not recommended) need to seal first.   In 20 years, you won't find most of the what's available today, so why worry?
When it comes to resto paint, I don't think you need to obsess over and have the exact original paint, just the original color, gloss, and appearence.   There aren't that many left out there that will know the difference and it's no longer original, if repainted anyway.
ps: I would think '57 Olympic white is not that difficult to match.   Alpine is the same as most bright whites today.   Olympic has a tint.   http://paintref.com/cgi-bin/colorcodedisplay.cgi?color=Olympic%20White&con=1&year=1957&rows=50
Offline Seville1957
« Reply #7 on: June 16, 2017, 10:19:48 PM »
I found a supplier of Olympic white paint for the 57, but was quoted over $500/gallon for lacquer! OUCHHHH
