Author Topic: 46 Fleewood 75 brake cylinders  (Read 544 times)
Offline bpowell
    • CLC Member
      CLC Member #29635
  • Name: Bill Powell
« on: June 12, 2017, 12:48:47 PM »
I need right and left rear wheel cylinders for a 1946 Fleetwood long wheelbase.
They should be 1 1/8 inch diameter.
Please help if you can.
bpowell
Offline harry s
  • Harry Scott 4195
    • CLC Member
      CLC Member #4195
Re: 46 Fleewood 75 brake cylinders
« Reply #1 on: June 12, 2017, 06:39:00 PM »
Bill, I have rebuild kits but not the actual cylinder.     Harry
Harry Scott 4195
1937 7529
1941 6733
1948 6267X
Offline Steve Passmore
  • Name: Steve Passmore
« Reply #2 on: June 13, 2017, 07:05:39 AM »
That's quite a large bore for rear cylinders Bill. You could with some fitting adaptions fit 1941 front cylinders, the replacements for these are 1&1/8"?
http://www.ebay.com/itm/41-42-46-47-48-49-50-CADILLAC-FRONT-WHEEL-CYLINDERS-PAIR/281053096760
Steve
Offline camelot
    • CLC Member
      CLC Member #28772
  • Name: Alex Cisero
« Reply #3 on: June 13, 2017, 07:20:04 AM »
 I just had my rear cylinders sleeved by Apple Hydraulics in Long Island. Very satisfied. Turn around was 1 week. They were sleeved to my original 1 3/32. I found him online for Shock rebuilding also.
1939 Cadillac 7519
1940 Lasalle 5019
1962 Cadillac 6339 4w
Offline bpowell
    • CLC Member
      CLC Member #29635
  • Name: Bill Powell
« Reply #4 on: June 13, 2017, 08:34:29 AM »
Thanks all, we think we have a couple located. Will have to wait and see what the guts look like.
These were only used on the Fleetwoods with the long wheelbase, according to the shop manual. The rear shoes were also wider.
Someone swapped them out for 1 inch ones, I'm assuming because the others aren't readily available.
bpowell
Offline bpowell
    • CLC Member
      CLC Member #29635
  • Name: Bill Powell
« Reply #5 on: June 19, 2017, 02:55:37 PM »
The cylinders we located were not as advertised.
Turned out to be Chinese manufactured 1 inch cylinders.
We still need the proper cylinders if anyone can help.
bpowell
Offline Mike Baillargeon #15848
    • CLC Member
      CLC Member #15848
« Reply #6 on: June 19, 2017, 04:11:12 PM »
I use NAPA.....check these two links out......the spec for the rears say 1 1/8" bore.
https://www.napaonline.com/en/p/UBP7536
https://www.napaonline.com/en/p/UBP7537
Mike   #15848
Offline bpowell
    • CLC Member
      CLC Member #29635
  • Name: Bill Powell
« Reply #7 on: June 19, 2017, 04:27:30 PM »
Thanks Mike,
We need the rears and NAPA doesn't list these.
Might try to find some fittings to let us use the fronts on the rear
bpowell
    • CLC Member
      CLC Member #15848
« Reply #8 on: June 19, 2017, 05:03:34 PM »
Hi Bill,
The 2 links I gave you are for the rears.
Are you saying that NAPA can't get these?
Mike   #15848
    • CLC Member
      CLC Member #15848
« Reply #9 on: June 19, 2017, 05:11:53 PM »
Bill your right, on the NAPA website they list the left & right front and left & right rear wheel cylinders with the same parts #.
They look like all have that 1 1/8" bore size your looking for though.
Mike     #15848
« Last Edit: June 19, 2017, 05:15:47 PM by Mike Baillargeon #15848 »
Online Bob Hoffmann CLC#96
    • CLC Member
      CLC Member #96
« Reply #10 on: June 19, 2017, 05:21:24 PM »
Bill,
 Are yours able to be honed?? If not, why not send yours out to be sleeved.
HTH, Bob
1941 62 coupe custom maroon
1970 DeVille conv. triple black
Offline bpowell
    • CLC Member
      CLC Member #29635
  • Name: Bill Powell
« Reply #11 on: June 19, 2017, 06:21:58 PM »
When I use those links, I just get listings for the fronts. When I try to look up rears for the Fleetwood long wheelbase, they show nothing available.
Some one put the wrong cylinders on the car, that is why I need different ones. The ones I have are the 1 inch bores used on all the cars. Should be 1 and 1/8 on the Fleetwood.
I would like to put it back the way it is supposed to be.
Bpowell
Offline Brad Ipsen CLC #737
    • CLC Member
      CLC Member #737
« Reply #12 on: June 20, 2017, 08:37:42 AM »
Not sure if I follow this thread exactly but the parts book shows that 42 to 48 fronts (1-1/8") interchange with rears of the opposite hand for 42 to 47-75 series 163" WB cars.  Any new listing that shows these fronts available would be highly unlikely to list the very obscure long wheelbase model rears as being the same.  Even if not available new it should be easy to come up with front cores since the fronts from 42 to 48 covers all models.  Just checked RockAuto and they list fronts for 1948 and are 1-1/8".  Cadillac parts book shows these are the same as rears for your model.
Brad Ipsen
1940 Cadillac 60S
1938 Cadillac 9039
1940 Cadillac 6267
1940 LaSalle 5227
1949 Cadillac 6237X
« Reply #13 on: June 20, 2017, 09:14:51 AM »
I gave a link to using front at the beginning of this.
Steve
Offline bpowell
    • CLC Member
      CLC Member #29635
  • Name: Bill Powell
« Reply #14 on: June 20, 2017, 11:02:53 AM »
The fronts have the flexible hose that is sealed to the cylinder with a copper crush washer. The rears have a tube seat, and the steel brake line threads directly into the cylinder.
I have some extra fronts that I could use, the issue is adapting to the steel lines.
I am sure there is way to adapt them, just thought I might be able to get some that could be used as is.
I appreciate all your inputs.
bpowell
« Reply #15 on: June 20, 2017, 01:00:56 PM »
In a country like ours where parts are unobtainable I've seen it done many times. A banjo is bolted on which takes the tube nut.
Steve
Get the CLCMRC 2018 Calendar - AVAILABLE NOW!
