Author Topic: 55 series 62 wiper switch  (Read 209 times)
Offline GasWorksGarage
  • Name: GasWorksGarage
« on: June 14, 2017, 10:49:06 AM »
Ok,
I know you all are going to think I am dumb but, do you pull the switch out or turn it to activate the wipers? I know they are vacuum but the knob will not move.
Thanks in advance C. Sams
Offline gatech1956
  • Name: D Steeves
Re: 55 series 62 wiper switch
« Reply #1 on: June 14, 2017, 01:40:08 PM »
in my 56 you just turn the knob. Probably the same for 55
« Reply #2 on: June 14, 2017, 02:02:58 PM »
I think the cable is seized and that is why I cant turn it.
Offline stzomah
      CLC Member #30309
  • Name: Wayne Elder
« Reply #3 on: June 15, 2017, 07:13:06 AM »
My cable was always seized.  I pulled the dash out last fall and finally lubed that sucker!  I soaked it in Kroil.  Check the screw on the wiper motor out under the hood.  Sometimes the screw and washer are torqued too tight and makes the cable bind up right at the end.  I happen to have a picture of my 56 wiper control from the back of the dash!
Here is a post about taking the cable out..
http://forums.cadillaclasalleclub.org/index.php?topic=137064.msg309059#msg309059
1956 Series 62 Coupe
owned since 1975
