Author Topic: 425 engine ac belt elimination 1979 Coupe  (Read 295 times)
Offline NickD
  • Name: N D'Andrea
« on: June 15, 2017, 07:08:20 AM »
Hi Group
I have a 1979 Coupe DeVille with a 425 cubic inch engine. I am removing the AC compressor, as I want to remove as much clutter as I can in the engine compartment. I do not care about AC. I noticed that this belt also runs the power steering pump. Is there a belt that just controls the power steering pump? I am unable to find a belt for a non-ac equipped Cadillac. My car does not have an air pump. Thanks any help will be appreciated.
NickD
CLC#29243
Offline The Tassie Devil(le)
  • Administrator
      CLC Member #18992
  • Name: Bruce Reynolds
Re: 425 engine ac belt elimination 1979 Coupe
« Reply #1 on: June 15, 2017, 07:40:42 AM »
I would have thought that the 425 is virtually the same as the 500, and my Eldo runs a single belt to the Power Steering Pump.
In the picture you will notice that the rear belt is to the PS Pump, and the front belt goes to the AC Compressor, and PS Pump.
The way the routing of the belts are designed set up, one can run without the Compressor.
      CLC Member #8621
  • Name: Eric DeVirgilis
« Reply #2 on: June 15, 2017, 08:21:07 AM »
Not the same as 425.
Removal of this important standard Cadillac accessory for the sake of "access" which should seldom be needed and leaving the system unsealed for an extended period is very shortsighted and foolish, in my view.
« Last Edit: June 15, 2017, 10:40:55 AM by Eric DeVirgilis CLC# 8621 »
A Cadillac Motorcar is a Possession for Which There is no Acceptable Substitute
Offline "Cadillac Kid" Greg Surfas 15364
      CLC Member #15364
« Reply #3 on: June 15, 2017, 09:59:34 AM »
Nick,
Here is a shot of using a (I believe) 48 inch belt between the crank pulley and the PS pump.
Offline Scot Minesinger
      CLC Member #20543
« Reply #4 on: June 15, 2017, 10:37:41 AM »
Answer:  You could take the old belt cut it, wrap it around the pulleys, mark it, and measure length with it straightened out.  Then request this size belt at any common auto parts store.
Comment:  I'm with Eric though, unless you are racing it like Greg does, leave it on with all hoses.  A 70's Cadillac closed car with no a/c is of much lower value than with a/c.  Understand it is your car, however it is nice to keep your options open if you want to sell it later.
Offline NickD
  • Name: N D'Andrea
« Reply #5 on: June 16, 2017, 04:42:43 AM »
Thanks guys for your thoughts and ideas.
