Author Topic: 55 Caddy series 62 questions  (Read 295 times)
Offline GasWorksGarage
  • Name: GasWorksGarage
« on: June 16, 2017, 07:42:49 AM »
Hello,
I am not trying to be a pain with all the questions. I do search the forums 1st before asking. I have a couple more questions.
1st. see the pictures below it appears I am missing a heater box inlet on drivers side am I not?
2nd. The autorionc eye isn't working I hear a buzz which I am told is normal. I do not have any bright lights when I cover the eye or press the dimmer switch which is my question there are to buttons on the floor side by side 1 bigger than the other which is the dimmer?
Where should I begin the diagnostic?
thanks
« Last Edit: June 16, 2017, 08:47:10 AM by GasWorksGarage »
Thanks in advance C. Sams
Offline J. Gomez
      CLC Member #23082
  • Name: J. Gomez
Re: 55 Caddy series 62 questions
« Reply #1 on: June 16, 2017, 08:35:00 AM »
Hello,
thanks
Well there are no pictures posted below ???
Hello,
thanks
I'm away from my main PC so I have to wing it from memory.  :(
There are a few posts related to the Autronic eye these are the same for the '55-'57 and if I recall correctly there maybe additional details also on them.
If you hear the amplifier pulsating as Walter mention the noise is from the vibrator inside the amplifier. The unit work with the eye at the dash. On the '55 there should be two floor foot switches one that operates the low/high beam and the second to enable/disable the Autronic function when it is on (high beam on).
There is a power relay next to the amplifier witch operates by the foot switch and/or the amplifier to switch low/high and high/low. If you can't get the high beams to come on it maybe a faulty power relay.
If do a search by Autronic you maybe able to find more details.
Good luck..!
J. Gomez
CLC #23082
Time is irrelevant when you work on your classic car, eventually you will enjoy it..!
« Reply #2 on: June 16, 2017, 08:48:25 AM »
sorry pictures added.
Offline marty55cdv
  • "Life" It's one Cadillac after another
      CLC Member #22760
  • Name: Marty Smith
« Reply #3 on: June 16, 2017, 08:53:23 AM »
   The heater box is indeed missing due to the Master Cylinder booster combination which isn't original to the car, can't help with the Autronic Eye .
Marty Smith
  CLC #22760
41 60 Special http://bit.ly/1Wm0GvT
55 CDV http://bit.ly/1G933IY
1958 Extended Deck http://bit.ly/1NPYhGC
1959 Fleetwood  http://bit.ly/1OFsrOE
63 Fleetwood http://bit.ly/1iSz17J
1964 Eldorado http://bit.ly/1Wm17GA
1988 EBC http://bit.ly/1iSACKz
« Reply #4 on: June 16, 2017, 09:00:02 AM »
these cars didn't come with power brakes?
« Reply #5 on: June 16, 2017, 09:07:55 AM »
how hard is the instrument cluster to pull out? I searched only found info on 59. which I believe is different.
Offline goofyhb
  • Name: Axel Joehnke
« Reply #6 on: June 16, 2017, 11:48:55 AM »
Please download the Shop Manual here:
http://www.oldcarmanualproject.com/manuals/Cadillac/1954/ServiceManual/index.htm
Disconnect the battery! The instrument cluster is held by 3 screws. One in the top center, 2 on the lower sides. You have to take off the speedometer cable first from the back. But as far as I remember you should let the steering column come down a bit. Therefore you remove the bolts on the floor and loosen the bolts on the bracket. Then you can pull the cluster a bit, so that you can unbolt the heater/fan levers on both sides. You should also pull all the instrument lights and other connectors before you pull out the cluster. These cables are not very long, so you won't want to brake one. Oh and not to forget the wiper control cable. Here I can't remember how it is done. You need to look that up in the manual.
1955 Series 62 Sedan http://bit.ly/1Ri914p
Offline 35-709
      CLC Member #4719
  • Name: G. Newcombe
« Reply #7 on: June 16, 2017, 02:46:11 PM »
They had power brakes but were not mounted on the firewall.  Someone has modified that car and taken part of the heater system out to put a "modern" power brake booster in it.  You REALLY should have a shop manual for that car --- easy enough to find on eBay Motors or follow Axel's suggestion.
1973 Cadillac Caribou - Sold
1950 Jaguar Mark V Saloon resto-mod
Offline 35-709
      CLC Member #4719
  • Name: G. Newcombe
« Reply #8 on: June 16, 2017, 02:50:10 PM »
Actually, you need the '54 shop manual AND the '55 supplement.  Here is one that claims to have both years together ---
http://www.ebay.com/itm/1954-1955-CADILLAC-SHOP-MANUAL-/152534319175?hash=item2383c10047:g:2rQAAOSwT~9WjvoO&vxp=mtr
Offline V63
  • Name: W Link
« Reply #9 on: June 17, 2017, 06:31:45 AM »
Check all your connections on the Autronic eye, remove and clean each one. The system is sensitive to good clean connections.
I believe the 55 has 2 heater cores? You could just make the right one functional? With global warming you should be ok!
They probably removed the box as it may have been rusted...but also seeking a substantial mounting for the master cylinder booster that was added.
Offline Jeff Rose CLC #28373
  • Name: Jeff Rose
« Reply #10 on: June 17, 2017, 10:46:38 PM »
I just got a manual for mine. It was $39 I think. I am posting a picture of the booster. It is up front forward of the powee steering pump.
Don't do feel bad about asking ?'s. That is what this forum is for. I have had our 55 exactly a week and I plan to post a few stupid questions tonite or tomorrow.
However, you need the manual---this isn't a Honda.
Sorry, rotate the picture 90 degrees clockwise. Is don't know how to do that.
« Last Edit: June 17, 2017, 10:50:20 PM by Jeff Rose CLC #28373 »
CLC #28373
1970 Coupe DeVille
1955 Series 62
« Reply #11 on: June 19, 2017, 09:04:00 AM »
Thanks all. I ordered a manual.
« Reply #12 on: June 19, 2017, 03:01:13 PM »
Are the heater boxes the same on both sides?
