Author Topic: Unwanted vegetation attached to my Cadillac  (Read 473 times)
Offline gary griffin
  • garygriffin@Q.com
      CLC Member #26430
  • Name: Gary Griffin
« on: June 18, 2017, 11:02:40 PM »
I took my car in for several minor repairs and they took longer than expected. My favorite shop personifies backyard mechanic. George was my friend and passed away leaving the business to his son who I met when he was riding a try cycle around the woods adjacent  to the shop. He grew up there and now 40 years later he does all of my work at "family  rate", but sometimes it takes longer. Basically I need to know the easy way to get the crap off of my car. Any help will be appreciated
Gary Griffin
1942 Cadillac 6719 (parts car) (Gone)
Offline lexi
      CLC Member #28634
  • Name: C.R. Foley
Re: Unwanted vegetation attached to my Cadillac
« Reply #1 on: June 19, 2017, 12:04:18 AM »
My car usually has a good coat of wax (therefore not oxidized), so I normally re-apply to any specific area to spot clean, ASAP. Afterward's the car's sheen always looks consistent, without the recently cleaned spots being apparent. Against my better judgement I made the mistake of parking under a tree at a Cadillac show a couple of years ago. By day's end my car was covered with sap or whatever from the tree. You could not see it, (as in your case), but the entire surface felt like fine sandpaper from whatever the tree shed. Wax did not work well in removing it so I used a clay bar with a detailer spray. While at it I re-waxed the car. The clay bar worked well in removing this type of contamination from vegetation. Three tiring days later I was finished and vowed to never park under a tree again! My other 2 buddies who parked their cars under the same grouping of trees had similar complaints and issues cleaning their cars. Nasty species whatever it was and wrong time of year I guess. So as I assume this is not an easy clean up job for you, and short of having pro-polishing skills and equipment, try a clay bar and follow the directions enclosed. If you have never tried this product you might be pleasantly surprised with the results and go for a full clean and wax as I did. Clay/Lexi
« Last Edit: June 19, 2017, 12:15:34 AM by lexi »
Offline chorusguy
  • Name: Robert W Cox
« Reply #2 on: June 19, 2017, 07:05:13 AM »
I believe rubbing alcohol takes sap off
Robert W Cox
Offline TJ Hopland
« Reply #3 on: June 19, 2017, 08:00:40 AM »
https://seafoamsales.com/bugs-b-gone/
Works great getting bugs off.   I have not tried it on sap but it works with grass clippings even after they have been there for months.   I also have used it successfully for mouse residue and pet stains.
Should be easy to find.   It seems to be sold everywhere Seafoam is sold which seems to be just about everywhere.
StPaul/Mpls, MN USA
73 Eldo convert w/FiTech EFI
75 Eldo rusty but trusty
80 Eldo Diesel
Offline lexi
      CLC Member #28634
  • Name: C.R. Foley
« Reply #4 on: June 19, 2017, 09:29:40 AM »
All good suggestions though if your car has a nice finish I would be concerned that rubbing alcohol may dull it by also removing the wax. I would imagine re-waxing the area you spot cleaned should even out the finish. Have never tried that bug remover either. Clay/Lexi
Offline TJ Hopland
« Reply #5 on: June 19, 2017, 09:37:55 AM »
I think the magic ingredient in the bugs be gone is a natural enzyme? that breaks down organic stuff.    Since its not a solvent it doesn't harm paint.
StPaul/Mpls, MN USA
80 Eldo Diesel
Offline 49er
      CLC Member #22010
  • Name: art archambeault
« Reply #6 on: June 19, 2017, 10:45:05 AM »
I  once a year clay bar my cars. Gets off all the environmental contaminents. Then I polish. Then a good coat of Gliptone wax. Its laborious. But works for me. The paint on my Eldo after 25 yrs looks pretty good. Some others here can attest to it.
Art Archambeault 22010.                                                           38 LaSalle, 5019
49 Series 62
62 Fltw, 60 Special
63 Eldorado  Biarritz Conv
01 Deville
  • garygriffin@Q.com
      CLC Member #26430
« Reply #7 on: June 20, 2017, 10:54:29 PM »
I finally got it all off with alcohol and scraping with old credit cards. A lot of work but no damage  to the finish except a bit where I tried alternatives.. Should polish out though.
Gary Griffin
Offline Chris Conklin
      CLC Member #25055
  • Name: Chris Conklin
« Reply #8 on: June 22, 2017, 07:31:28 PM »
I'm a little late to be of help (story of my life)... but for sap I've always used WD-40.
Chris Conklin
