replacing the rear transmission seal 55 series 62
Started by GasWorksGarage, June 20, 2017, 10:58:39 AM
GasWorksGarage
Hello,
I have ordered a manual but it will not be here until Monday. I am going to replace the rear seal in the tail shaft on the transmission.
Looks pretty straight forward. I pull the drive shaft pull out old seal and replace with a new one.
Am I missing anything?
Thanks in advance C. Sams
Caddy Wizard
Yes, it looks like an easy job.  It isn't.  I have done it several times and find it to be very difficult.  If you have the right seal puller, not too bad.  Without it, very hard to remove.  The interference fit between the seal and the housing is too great, IMO.  I have done this in as short a time as 4 hours and have spent a whole day doing it.
Good luck...
Art
Art Gardner
1958 Eldo Seville (2/3 done)
GasWorksGarage
goofyhb
For the 1955 transmission the shop manual tells you to use a certain tool. For a 1962 transmission it comes clearer to what everybody does when it comes to replacing this seal. Attached are both descriptions from the service manuals.
1955 Series 62 Sedan http://bit.ly/1Ri914p
1949 Buick 56S
1960 Series 62 Convertible
1960 Fleetwood
GasWorksGarage
thanks all. Took about 10 minutes to get old seal out. about 45 minutes all together
Mike Baillargeon #15848
C. Sams did you use a slide hammer?
Or some other tool?
Mike  #15848
Baillargeon
#15848
GasWorksGarage
Mike,
I used a thin screw drive to fold down the outer edge of the seal then it came right out. I tried a slide hammer but it ripper thru it.
