1967 DeVille Transmission indicator light
Started by Julien Abrahams, July 19, 2017, 04:38:15 AM
Julien Abrahams
Hello everybody.
I just have a quick question. The transmission indicator quadrant bulb has decided to quit after almost 50 years. The quality of these things is just appaling:). hihih.
Is this bulb easy to access (like the ignition lock light) or is it part of the instrument cluster (which can be removed after removing the top dash pad and I don't really want to do).
Thanks.
1954 Cadillac series 62
1969 Austin Healey Sprite
1979 Opel Kadett
Julien,
You should be able to access the bulb by dropping the lower cover at the steering column.
