67 windshield washer pump lubricant?
Started by 67_Eldo, July 20, 2017, 09:46:36 AM
67_Eldo
I'm rebuilding the windshield washer pump in my 1967 Eldorado and, after cleaning out the old, dark yellow grease, I'm wondering what lubricant should be used when I reassemble it. I'm tempted to spray everything down with graphite lubricant but maybe I should use white grease instead? Opinions?
While the wiper motor is (sort of) exposed, should I squirt/pack anything in there as well?
Thanks!
P.S. I joined the CLC!
cadillactim
I use white lithium grease when I rebuild them. Some use the green grease because it is waterproof but it's not necessary.
Tim
Tim Groves
67_Eldo
